-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/975730-question-brake-pad-replacement.html)
DIESEL DON (guest) 10-29-2017 06:45 AM
RENEWED FRONT PADS +DISCS ON 2007 MINI WITH NO PROBLEMS.
BUT OUTER PAD ONLY TOUCHES HALF THE DISC.
BRAKES PULL UP EVEN WITH FIRM PEDDLE
IS THIS A 'WEAR IN'PROBLEM ONLY DONE AROUND 50 MILES SINCE JOB FINISHED
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Pad Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-29-2017 06:45 AM
Can you share a photo of the problems? It sounds like the caliper is faulty.
- Nick
Luccia at Pelican Parts 11-03-2017 08:52 AM
Might be getting stuck, but make sure check over your job. Is it only one one side?
