Go Back   Pelican Parts Forums > 3- European Cars > MINI Discussion Forum
Bill (guest)
Guest
Posts: n/a
2010 Mini Cooper Clubman S - How do you determine if the problem is the fuel pump in the gas tank, or the High Pressure Fuel Pump, driven by the Intake camshaft? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 05:54 AM
By testing the low pressure fuel delivery system using a gauge, then testing the high pressure system using a scan tool like Autologic AssistPlus.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
To test the HPFP, look at figure #10 in this article here: MINI Cooper R56 Fuel Pump Testing (2007-2011) | Pelican Parts DIY Maintenance Article
Old 11-03-2017, 08:11 AM
