Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
bcgreen's Avatar
Anyone replaced headlight cover?
2004 MC40. I have not found anyone who has done this and I am not sure if I can just replace the cover or do I need to buy the whole headlight assembly?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-23-2017, 07:00 AM
Administrator
Luccia at Pelican Parts's Avatar
Are you talking about the ring around the headlight or the lens on the headlight?
If you're talking about the lens on the headlight, I do not believe there is an aftermarket or genuine option lens available. You may want to go some research on that. If you do not find anything, you'll most likely need to replace the whole unit, which isn't very expensive if they're the Halogen units. If you give me the last 7 digits of your vin I can confirm what headlight you'll need, but here are your options so you can see how much they cost: 2004 Mini Cooper S Hatchback - Lights and Lenses - Page 4
Old 11-27-2017, 03:49 PM
