Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ferri208 (guest)
Guest
Posts: n/a
The vacuum pump of my 2009 MCS is leaking oil. I purchased a vacuum pump O-ring to reseal the pump I have not replaced the O-ring yet. Yesterday, a got a misfire and 4 error codes: P0503 Speed Sensor, P1497 Downstream Throttle Air Leak, P0303 Misfire Cylinder 3 and P0300 Combustion Misfires Several Cylinders. It is possible that the code P0503 Speed Sensor and P1497 Downstream Throttle Air Leak could be caused by the vacuum pump? The car has other issues.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Vacuum Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:05 AM
No, not likely. Most likely other issues causing those faults.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Seems you have multiple issues going on. When is the last time you replaced routine maintenance items on your MINI? Such as filters, spark plugs, etc?
Here is some info on P1497: http://forums.pelicanparts.com/bmw-mini/940120-vent-tube.html
For P0503, check and see which wheel speed sensor is your issue. You can specifically find out which one is an issue with the proper scan tool.
Old 11-15-2017, 09:59 AM
