-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Pressure Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/975761-question-turbocharged-engine-pressure-sensor-replacement.html)
J (guest) 10-29-2017 07:19 AM
I'm getting a P115C code. Ive put in new MAF sensor, new valve cover and new boot from MAF sensor to turbo intake. and still getting code. But no other codes. Could this engine pressure sencor have anything to do with it? . Its a 08 n56 turbo engine
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-29-2017 07:19 AM
if the intake system is free of obstructions and no leaks, the timing on engine may be off.
- Nick
Luccia at Pelican Parts 11-15-2017 09:27 AM
Valve cover would've been my first note, but since you replaced it you should definitely check your timing. I'd suggest checking your throttle body. If your timing is fine, check the TB. Also, double and triple check your intercooler piping. Let us know what you find out.
