-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Timing Chain Guides Replacement (http://forums.pelicanparts.com/mini-discussion-forum/975766-question-turbocharged-engine-timing-chain-guides-replacement.html)
Shan (guest) 10-29-2017 06:22 AM
Never mind guys, it turned out to be a stupid mistake after all. Finally had a chance to open up the ignition coils and test the ignition. Found that all plugs from the harness wire to the ignition coil had bent electrodes so the plug was not going all the way in but enough to lock into the coil.
It is highly unlikely to screw up the timing if crankshaft is rotated with the timing chain is in place but I was worried reading other forums.
Thanks - Shan
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-29-2017 06:22 AM
Glad you figured it out. Thanks for the follow up.
- Nick
