Go Back   Pelican Parts Technical BBS > 3- European Cars > MINI Discussion Forum
Skots (guest)
Guest
Posts: n/a
Iâ??ve got an 09mcs that is reading 1100psi on the fuel rail at idle. I only have a code for too rich at idle and too lean off idle. What would cause my pressure to be so high? Could a failing pressure sensor do that without setting a code?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
How are you reading pressure? Can you share a photo of the reading?
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
