Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
stude6
POWER STEERING PUMP 2006 mini
2006 Mini. Changed PS pump and cooling fan, checked all fuses including the 100 amp, still doesn't work. how do you bench test the pump.
Old 11-07-2017, 05:27 PM
Administrator
Luccia at Pelican Parts's Avatar
Hello there - Did you check your alternator/is the battery light on? Any fault codes in the DME? I know when alternators pose an issue, you can have some p/s issues. Go to this article MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article and scroll to the bottom. Leave a comment and our tech should have some additional input for you.
Old 11-15-2017, 08:56 AM
