Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Tire Pressure Monitor
Is there anyway to disable the tire pressure monitor on a 2008 mini cooper convertible base model? The light on mine stays on all the time sometime flashing but the air pressure is Ok. I have tried resetting it but it comes back on after a few miles. Just want to get rid of the light on my dash. Thanks.
Old 03-31-2018, 12:33 PM
Administrator
Luccia at Pelican Parts's Avatar
You might be able to code it out with a MINI reader, but it make take an NCS expert to do so. Otherwise, I do not believe you can and will need to fix the broken sensor that is triggering the light. We can get you one if needed. Just let me know the last 7 digits of your vin.
Old 04-01-2018, 03:44 PM
TF68440 How can I find out which one to replace?
Old 04-07-2018, 09:56 AM
Administrator
A MINI scan tool should tell you which wheel is throwing the fault.
https://www.pelicanparts.com/techarticles/MINI_R56/27-SUSPEN-Tire_Pressure_Monitoring/27-SUSPEN-Tire_Pressure_Monitoring.htm
Old 04-09-2018, 03:12 PM
Tags
tire pressure
