Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Broken hood cable.
How can I open the hood of my 2008 mini Cooper s model with a broken hood release cable?
Old 05-31-2018, 12:24 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! I'm including a suggestion on how to open your hood from an earlier thread; hope this helps you a bit!
"Usually when the cable breaks, it is at the cabin end of the cable and not the engine side. Take a look underneath your your dash, you should be able to see the broken end. Grab a hold with a pair of pliers and pull the end, the hood should pop. There is also the possibility that the cable pulled out of the little bracket at the release lever. You might still open the hood, by holding the sheathing and pull on the cable. A pair of vise grips may make that job easier.
"Using a hacksaw blade, you can ease the kidney grills out of the bonnet, this allows you to release the left hand bonnet release by yanking on the cable that runs under the front cross member. You can't get to the right hand one through here though.....
To release the right hand one, pull off the lens cover from the RH headlamp. EEEeek I know!!!!! , but mine didn't break and all i'll have to do is silicon it back on after the plastic clips broke. This reveals a space behind the indicator that allows you to ferret around to locate the release cable that runs over the headlamp and up the inner wing."
Old 05-31-2018, 01:47 PM
