Go Back   Pelican Parts Forums > Regional Forums > New Zealand / Australia
Tarmac rally video question
Because there's never enough to do on a 4 day tarmac rally.....
we plan this year to mount video capture stuff.
But here's the challenge. A complete single unit (lens and recorder) minicam will self power down in typically 5 minutes of non-use. The remote will not kick it back into life. B3 is too cramped in the cabin to reach back to the camera and turn it on for each stage & 1 hour tape life makes recording the whole thing too hard.
Second option is to mount a remote lens unit (lipstick type) and run that into a mini DV deck, again space is too limited to mount this within reach of the silly seat.
We're not the first to face this problem. Ideas??
Many thanks
Brett
Old 08-27-2006, 11:38 PM
Bird. It's the word...
Fishcop's Avatar
Hi Brett
There is some massive info on this over on the 'Merican boards - try the track forum. Jack Olsen has thread after thread on his digital hard-drive recorder (with multiple camera angles inside and outside the car), it's hardwired and has remote control. All put together with relatively cheap parts. I think some of the camera set ups are "web quality" only, but I know some of those guys produce genuine DVD quality stuff.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-28-2006, 01:00 AM
brettles
i fitted an DC to AC inverter so the camera 'thinks' its on mains power.
before a stage, you simply switch the inverter off then back on (via a dash mounted switch) which should reset your camera's internal timer (it does for a sony).
the only downside is your navigator must remember to do this AND press record on the remote...
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 08-28-2006, 09:37 PM
ps: it also means no stuffing around with batteries/chargers etc
Cheers, Ryan
John - thanks for that - you're right there is a recent and detailed post from the great J. Olsen but the systems they propose are too low in resolution for my needs.
Ryan - seems poor 'ol Stuart will continue to be punished for the unfortunate 'Navigator in Space' incident......I can hear him now.."I f*** one goat"...
And it also appears that there is a confrontingly high level of videography expertise in my place of work - who'd a thunk it? The boffins advise that both hard wired power or menu option to not power down are avaialble with our cameras. But my real concern lies in mounting a kilo..ish of metal at head height (was there not a tragic event with an MX5?).
So today's plan involves an auto apperture adjusting lipstick head unit into a DC powered mini deck mounted to the rear floor and a LANC remote within reach of Stuart for start/stop. Sony are assembling this system as we speak. Are you running vid stuff this year?
Old 08-28-2006, 09:54 PM
"Are you running vid stuff this year?"
yes.
will i ever watch it (more than once), convert to digital, upload to youtube etc?
no - based on experience to date
ps. the camera housings have to be pretty sturdy to pass CAMS spec
Cheers, Ryan
Old 08-28-2006, 11:15 PM
