-   -   Headlight restoration. 10 minutes, a rag and some Crest toothpaste. (http://forums.pelicanparts.com/off-topic-discussions/1002342-headlight-restoration-10-minutes-rag-some-crest-toothpaste.html)
dan79brooklyn 07-16-2018 04:44 AM
The Turtle Wax kit is supposed to be a good. Less than $10. Includes a protective sealer.
https://www.walmart.com/ip/Turtle-Wax-T240KT-Headlight-Lens-Restorer-Kit/16927980?u1=-%20&oid=589058.1&wmlspartner=xzXATABADTI&sourceid= 35822976070166944501&affillinktype=10&veh=aff
I have been using a different headlight polishing kit. It gets the lenses clear but they still look a little yellow (Benz w210).
fintstone 07-16-2018 06:15 AM
Mine were yellow until I wet sanded first. Now they are perfect.
sugarwood 07-16-2018 06:50 AM
Originally Posted by fintstone (Post 10108632)
Don't even need an orbital. Easy to do by hand.
The correct way is to wet sand down to 2500 grit, and then you absolutely need an orbital.
Or 20 years of hand polishing. Nothing matches the RPMs of an orbital.
fintstone 07-16-2018 06:53 AM
Originally Posted by sugarwood (Post 10108915)
If you wet sand down to 2500 grit, you absolutely need an orbital.
Takes me less than a minute by hand (after wet sanding with 1600 paper)...and would certainly not waste my time wet sanding with 2500 grit paper (might as well use notebook paper. Maybe I am special.
Instrument 41 07-16-2018 08:54 AM
Done this on many cars. The best kit out there is one that's made by 3M. Multi stage sanding by hand or drill. The new kits actually have a clear to apply to the lens after the final wet sand. Its awesome.
vash 07-16-2018 02:22 PM
done it twice. turned them damn near into diamonds. super shiny, super clear.
i even use some UV coating. best i got was a year of bliss. i think they yellow/haze worse than when i started.
i drive a tacoma, so i'm lucky there is a huge group of folks modifying them. i found factory take-offs for $100. they are in such good shape and i am on 2 years of bliss.
flatbutt 07-16-2018 04:36 PM
oh! oh! oh! Mr Kotter! Mr Kotter! Please do tell.
Don Ro 07-22-2018 03:30 PM
Just watched this.
<iframe width="560" height="315" src="https://www.youtube.com/embed/uqOKmZ9mMfc" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
sc_rufctr 07-22-2018 04:55 PM
I fixed my daughters car a few years ago. The word got around :rolleyes: and I've now done more than 20 cars! (all for free)
http://forums.pelicanparts.com/uploa...1532303568.jpg
http://forums.pelicanparts.com/uploa...1532303604.jpg
http://forums.pelicanparts.com/uploa...1532303625.jpg
Don Ro 07-22-2018 04:58 PM
Spanking clean. Did you use the last method that's in the vid I posted?
What sequence/method did you use?
sc_rufctr 07-22-2018 05:05 PM
I use pro paint cutting compound and a lambs wool bonnet. They last about 18 months before they need redoing.
IME the coatings/lacquer are a waste of time. Halogen head lights get very hot and I've seen some coating go yellow.
rcooled 07-22-2018 06:04 PM
Originally Posted by HardDrive (Post 10108391)
25 cents worth of toothpaste, and a little elbow grease...
I once used toothpaste to remove paint residue from a rental car's fender after I brushed against a painted pole in a parking garage. Had a plane to catch and no FLAPS nearby. There was no permanent damage to the paint and the toothpaste did a great job of removing the telltale paint streaks.
