Not another air cooled question
I know you guys are all about air cooled but I have a water cooled question. Last winter the AC went out in my truck.I said to myself, self, you have to have AC by summer. So instead of a new compressor for the truck, I built a new truck with a new compressor. A 94 S10 with a 350 SBC, and big fat tires on the back. The air is very cold but the 350 is getting very hot at idle. My question is, do I need a better radiator or a better fan. Current radiator is from a 97 Blazer. Biggest stock type that will fit. Fan is a 17" flexfan, motor driven. Shrouds are in place. I'd like some opinions, fan or radiator ??
Pics of said truck below. http://forums.pelicanparts.com/uploa...1535762519.JPG http://forums.pelicanparts.com/uploa...1535762519.JPG http://forums.pelicanparts.com/uploa...1535762519.JPG |
Fan running backwards. Electric I assume.
Do you have a shroud? how close is the fan to the radiator... if it is happening at idle.. perhaps an electric fan would move more air at idle that the engine driven fan is currently moving.
It is important to have the fan sitting inside the shroud at the correct depth to pull the air without bypass.
Is your fan capable of moving enough CF/M air flow via the engine power, or is the only reason it doesn't over heat at speed is because of air flow at speed? Especially when the engine is running at low RPMs... like a stop after running at higher RPMS for a bit (and getting hot).
I have seen the temp gauge on my 356 be dead center, sit at a stop light in the florida sun for a few minutes and its moved noticeably hotter and more than a hair. Get going again, couple of minutes at 25+ and it drops back down again. If you want to geek it out, I'd look at extra fans for air movement, and set them up so they can run for a few minutes after engine is turned off. |
Can you easily swap in a non-flexible fan and/or smaller fan pulley to see what happens?
Shroud is in place. Fan is 3/4" from radiator. No room for adjustment on the fan. Motor is back, almost touching the firewall. Electric fan may be the fix. Or a bigger radiator ?? Just looking for opinions, fan or radiator ?? Maybe a bigger radiator and an electric fan ?? I do not have much room to work with.
I had one in the 90s, loads of fun. Foggy memory but IIRC I had a ~90 1500 chevy radiator. Was pretty thin but wide. I added a higher flow pump at some point, used a standard summit flex fan too. Now you can get a bolt in custom radiator, I would go that route. Superior is one I think, was thinking about another one of these recently.
I have a high flow Corvette pump. General consensus seems to be the fan. Electric puller will be a tight fit. I think I have 2 1/2" between the water pump and radiator.
Sounds like the fan is to deep inside the shroud. Can you get a low profile water pump for this engine?
Electric fans that move equivalent air are expensive. You will need a puller and a pusher with the puller being more efficient so it should be the largest size possible. |
I looked at the Superior option. Nice. $350 but nice. It would be worth $350 if I knew for sure it was the fix. Have to keep looking at options.
Ask these guys
Thermostat.
T-stat going bad usually causes worse overheating under load, though not a bad idea to replace.
Then timing is retarded.
I know you asked fan or rad and I'm sure this isnt what you want to hear but to me its both. Check the inlet and outlet of the rad with a IR thermometer. Good delta? If not, try a box fan in front, make any difference? Dont mean to be all over the map but I'm tired. :) Timing good? Not too lean? I had exhaust issues at first, that heated up the engine bay quite a bit too.
Summit sells a rad too Radiator Style: Crossflow Overall Width (in): 30.750 in. Overall Height (in): 15.875 in. Overall Thickness (in): 3.125 in. |
Look at distributor and vacuum advance.
Also...how are you running the water pump? Pulley/belt or serpentine? |
Inlet and outlet check is a good idea. Not likely lean. Idle smells rich. I have a bung in the exhaust for a wide band O2 sensor but that I have not purchased yet. Will look at the Summit radiator too. |
Not much truck time today. I checked timing, 12* advance at idle. 17* drop from radiator inlet to outlet. At least its doing something. Think I will check my old truck. Completely original and never gets hot.
50* drop. I just remembered something. I have a large transmission cooler in front of the radiator. It blocks a lot of air. I will do something about that in the next couple days and report back. Fingers crossed.
Is the 97 Blazer radiator you are using known to be good ? Is it possible it's partially clogged internally ? What condition are the fins ? They need to be clean and straight to allow sufficient air flow/heat transfer .
If it only overheat when idling and not when driving down the road under a load... you probably have to rethink your fan design.
I swapped out the transmission cooler last night to a smaller one. I will see how it does today.
trash the shroud and fan
Big pusher fans are all over the place for cheap. Shrouds are only stopping air flow. Rip out the weatherstrip under the hood to allow hot air to escape. Engine fans are limited I RPM and suck horsepower. Use coolent additive - reduce antifreeze proportions.
heat kills |
Use paper to test airflow at idle.
Flow should be able to strongly hold a thick piece of paper to radiator front at idle. |
Transmission cooler was a problem, for sure. Went for a drive, AC on. It is 85* F ambient here. Got back and it was 210*. I idled in the garage and it creeped up to 222* and stayed there for 10 minutes. I think I will swap the fan out for a pair of pushers. As stated above, they are all over the internet and cheap.
Thanks for all the input and ideas. I needed that. |
You may have too little capacity, coolant volume. If the radiator is not large enough ( volume) your problem will likely persist. Specifically not the surface area for air flow, but fluid capacity for your combination.
Pretty sure someone makes a radiator for the conversion. May be pricey initially, bit it solves the actual problem. With projects like this - it's the price of admission to have the bugs worked out. Sounds simple but easily the 3 basic items. Good tires, good battery, proper cooling system - because without any 1 of those you're not going anywhere regardless if the time, effort and money spent.
Just for fun - I checked fluid capacities for a 1994 S10 cooling system. 2.3 engine 11.5 quarts. 4.3 engine 12.1 quarts The same year full size truck with a 5.7 is 18 quarts.... Obviously there are many factors that come into play but it's pretty obvious that the factory felt the 5.7 (350) needed a whole lot more coolant than the four cylinder or six in the S10. angela |
Update. Truck now has 2 10" fans pushing through the radiator. Only 88* F today but it only got up to 204*. That is a 20 degree drop compared to before.
| All times are GMT -8. The time now is 01:32 AM. |
