Now in 993 land ...
aigel's Avatar
What's this thing worth? Miller 330A / BP Welder (in LA)
Buddy of mine inherited this welder ... What is the going rate for this? It is in the greater LA area - any of you LA guys interested? He just wants it gone. It looks BIG!
G
81 SC (sold)
Old 09-10-2018, 08:21 AM
Zeke's Avatar
That is a beast. An old beast at that. They weigh close to 800 lbs and require a lot amps to run. Like 50-70 amps and they need more if you want to turn up the heat. So, to answer your question, not much. Whatever he can get. Might ask 500 and take it from there. On the bay they are all over the map.
Old 09-10-2018, 08:43 AM
Steve F's Avatar
I have a 400 amp P&H tig/stick at least that big. Paid $200 for it 25 years ago. A total beast that just won't die:<) Copper windings, not aluminum.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 09-10-2018, 09:01 AM
908/930's Avatar
I had the same 300A, picked it up for $200 in the late 80's ended up giving it away when I moved. The foot pedal is about $300 new if you need it. The weight does not help there value, I ran mine on 240v 60A single phase and could only weld thin aluminium up to under 3/16", it needed lots more current get to its rated output. $500 starting price sounds about right.
Old 09-10-2018, 09:35 AM
I will be surprised if he can get $500....
Ask $500, if he gets offered $200 take it.
Or make jumper cables out if the weld cables.
Old 09-10-2018, 12:49 PM
Now in 993 land ...
aigel's Avatar
Thanks everyone - It is in Downey, if any of you LA guys are interested. Let me know, I don't think it would cost much ...
Lots of copper in it, so a scrap guy may like it!
G
81 SC (sold)
Old 09-10-2018, 01:23 PM
7.0:1 > 11.3:1 > 7.0:1
Those are solid machines. Size and weight are both over the top but if someone wanted to try their hand at tig these machines are an economic entry. Dont send it to scrap! someone would be happy to get their hands on it, only exception is if its 3ph.
edit, a manual for it would still be on the web and likely still on millers site. Also, make certain the foot control stays with the machine, so often they go missing.
Old 09-10-2018, 03:41 PM
