On demand hot water recirculating pump- what brand/model?
Pelican Braintrust,
I am tired of watching water go down the drain waiting for the water to heat up. I did a search and found these posts about recirculating pumps, but nothing about which model to buy.
Home recirculating hot water heater
Any Pelican plumbing and hot water gurus ?
I would like to put a on demand water recirculating pump under our sink that will work with our tankless water heater. I don't want something running on a timer, but rather a push button. Any one have a recommendation on which pump to buy? This one on Amazon looks good, but the reviews point to a short longevity.
Any tips would be appreciated.
Neil
Neil
'73 911S targa
Old 10-31-2018, 04:29 PM
On demand and tankless do not go together in a sentence.
Inorder for you to have hot water a couple of seconds after you turn on the water, readily available hot water must be near by near by. I mean, within 3to 5 feet. The pump acts as if you were using water but it returns back into the line and recirc. itself. It can be done, but it involves a lot more piping then just screwing in a pump under the sink. I have a recirc on a timer and a thermo. switch hooked up to a tankless heater. That recirc. pump has to be large enough to push water through the tankless unit because it requires a certain volume of water going through it to turn it on to produce hot water.
Old 10-31-2018, 04:39 PM
beancounter
jwasbury's Avatar
My contractor plumbed a hot water loop in as part of our full gut renovation. Taco circulation pump on a timer is set to run for a several minutes at strategic points throughout the day to help insure there's not a long wait for hot water.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 10-31-2018, 04:43 PM
I have on demand and a pump.
It used to take a very long to get hot water from the tank in the basement to my 2nd story master bath. Think minutes.
When we remodeled I added another line from the basement to my bathroom that tied into the plumbing and now have hot water in seconds.
I can look at the brand when I get home.
Old 10-31-2018, 04:46 PM
What the previous two guys said...
Old 10-31-2018, 04:47 PM
The Unsettler
stomachmonkey's Avatar
Installed when we built our house.
Won't ever have a home without it again.
"I want my two dollars"
"Brandon Won"
Old 10-31-2018, 05:09 PM
Make sure your plumber know what the heck he doing with it comes to recirc pumps. There must be a way to shut off the heater after a hot water cycle. If not it will burn the tankless. Most mfg will void warranty if there's a pump hooked up to it.
Old 10-31-2018, 05:16 PM
The timer based pumps I have seen turn off after reaching 90 to 100 degrees, so the water is hot within seconds of turning it on. Our schedule is too unpredictable, so I want push button operation.
As I understand it, the pump bridges the hot water to the cold and recirculates the water until it reaches a set temp. Since we are tankless, the key is getting enough water circulating to trigger the pump.
Neil
'73 911S targa
Old 10-31-2018, 06:57 PM
A return line is needed to bring the cold water back to the heater from the faucet to recirculate it through the system keeping all pipes steaming hot. I believe the some of the newer pumps has a temp. sensor built in, so when it reaches a certain temp, pump shuts off leaving hot water throughout the pipe between faucets and heater until it drops to a certain temp., pumps starts up again, another cycle. My system would come on every 15 min for about 20 second keeping the water piping hot. It goes on a little more often during winter but it doesn't get too cold around here. The timer is there so the pump can be completely turned off during a set time such as after midnight to 6 am. to keep wear and tear on the system where hot water isn't needed. Tankless heaters takes an additional 30 -60 second to get water to it source. That's normal. Now, we have hot water in less then 5 seconds.
Old 10-31-2018, 08:37 PM
My system sounds a lot like Look’s.
Old 10-31-2018, 09:43 PM
You do NOT use a recirculating pump with a TANKLESS heater.
Old 10-31-2018, 09:45 PM
That's the way it suppose to be done. I used my own house as trial and error about 15 years ago when tankless heaters started to gain popularity, a time when most plumbers were not used to having a heater shutting off, so they wired pumps to run continuously like a tank unit. They were getting into all kinds of issues. We replaced so many screwed up installs. We finally has to train my plumber on how to install these thing correctly so he can service our clients (thankfully that type of work stopped). Most good plumbers get it now, finally.
Old 10-31-2018, 10:01 PM
A pump sure can be used, but not always cost effective due to the somewhat complex install.
Old 10-31-2018, 10:03 PM
My circulating pump seems different than what's being talked about. My tankless heater for the back part of the house serves the bathrooms. If you want quicker hot water, there is a button to push that causes the pump to operate long enough to circulate hot water through the loop for whose bathrooms and then shuts off.
Marv Evans
'69 911E
Old 10-31-2018, 10:07 PM
Interesting. Is it automatic or manual only?
We have gotten away from a single tankless due to additional labor for pump times and such. Now, I push for two smaller heater located neat bath and kitchens without pumps.
Old 10-31-2018, 10:16 PM
Send a message via AIM to fintstone
I use a RedyTemp ATC3000 Hot Water Circulator on-Demand Circulation Recirculation Pump in my vacation home (regular hot water heater, not tankless). I mostly use it because it keeps the pipes from freezing in the winter. I can remotely turn it on from anywhere (and the hot water heater...also on a wemo switch). I leave both off when I am away and it is not cold out (enough for pipes to freeze). Just place it at the faucet that is farthest away from the hot water heater in the circuit...and it will fix your problem for all in between. It is not cheap to buy, but is safe, well engineered, high quality, easy to install, and saves water and electricity. I use a wemo plug-in to control it from my iPhone, but it comes with a timer if you prefer. You can also use a motion sensor or a switch (if you prefer) to use whenever you go in the bathroom and by the time you get your clothes off...hot water. When I ordered it...it took a few weeks and i began to worry...but then it arrived. Guess the guy sells them out of his house or something.
They also sell a version for tankless water heaters.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-31-2018, 10:31 PM
Brew Master
cabmandone's Avatar
Years ago a friend of mine plumbed in a gravity loop but he didn't have a tankless heater.
IIRC a tankless needs to see a minimum flow to begin heating so you'd want a pump capable of maintaining that flow rate.
Nick
Old 11-01-2018, 04:10 AM
greglepore's Avatar
The newest tankless units come with a recirc built in...my Navient has one.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 11-01-2018, 06:27 AM
I'm using the Watts system from HomeDepot. It uses the cold water pipe as the return. Easy to install works good enough. Saves adding a pipe for the return. Works on a timer.
Sold: 1989 3.2 coupe, 112k miles
Old 11-01-2018, 07:26 AM
I've had a system like this for a number of years (15+). The issue here is that, while the hot water is pretty much instantaneous, if you want cold water, it is not cold (you have to wait for the hot to flush through). For systems that have plumbed a completely discrete hot return line, that's great for new construction, or major renovation work, but more challenging as a more basic add-on. Still, at our house, we use more hot water, and more often, than cold, so the cold return method is still pretty good.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 11-01-2018, 07:43 AM
