GM 8.1 Harmonic Balancer - 496 - How to Install?
Anyone know how to install the harmonic balancer? It is not keyed and a apparently an interference press fit?
I don't think you can heat the balancer, I don't think dry ice on the crank alone will do it, not sure how to press it. I'm asking for a friend, but we are both stumped. |
Never done one on an 8.1 , is there a threaded section in the snout of the crank? They've been doing this on other engines for years now. I have a tool that threads into the crank, and pulls it in.
That's a GM tool, I assume?
That one is, but I have a generic kit that does them all . Ill loan it out if you need it. It is the correct way to install any pressed on harmonic balancer
Usually I put a big bolt in it and use greased washers to stack under the head to push it on, that or
All thread in the crank snout, with a thrust bearing and a nut to drive it on, it helps to warm the balancer with a hot plate. |
Got it. Thanks for the help.
If you don't have the fancy tool, I'm sure this would do the trick.
https://ae01.alicdn.com/kf/HTB1FjN5K...pg_640x640.jpg |
rjp |
Without a keyway, etc. how do you keep it from moving?
Or is it so tight, it just won’t move? |
I believe the interference fit prevents slipping.
| All times are GMT -8. The time now is 12:38 PM. |
