That winch does not look like it is designed for a high duty cycle at full load.
Look for something Jeep related...high torque meant for real off road use. |
As well that rating is probably for a vertical lift. Dragging a log will be huge.
Float them suckers down stream like we did in the old days!
Not that I'd know how it was done in the old days since you're older than me... but still! |
If ya don't have forks...get some :) Oh yeah....we rarely use our winches & come-alongs....straps & the JD work fine. |
I have forks but they would be useless down there. I can barely get the tractor between some of the trees. But an ATV would slip right through! I like where this is going. |
You obviously need this. With a winch of course.
https://cdp.azureedge.net/products/U...2000000002.jpg |
http://forums.pelicanparts.com/uploa...1542401604.jpg |
this is what you need
http://forums.pelicanparts.com/uploa...1542410411.JPG
I think I figured out how to post pix. I built this log carrier |
Find a used one of these. I think i paid 1200.00 for it many years ago. Can't even remember if it's a Farmi or a Fransguard but it will pay for it self if you burn a lot of wood.
http://forums.pelicanparts.com/uploa...1542412907.JPG |
Since you have a tractor..get a snatch block, a good length of cable some cable clamps and shackles.. fix the snatch block to a tree at the top of the slope, run the cable down to the logs (which you cut up into manageable lengths) choke the downhill end of the cable around the log.. cable through the snatch block... other end of the cable fastened to the pintle on the tractor..
Pull those suckers up.. With a little help you could get all that wood up in a few hours... relocate the block for more advantageous locations as needed.. |
Forgot to add I used my F250 Diesel to clear a bunch of stumps etc from my Vermont property using a length of cable and a block..
I'm still not sure how I'm going to do this, and it's pretty obvious in the light of day that that little winch isn't going to do it all on it's own, but the winch sure seems like a handy thing to have around. |
OK, so I went ahead and bought it. It's definitely not as cool as Paul's helicopter.
Long story about why I got it below. On to the product review. http://forums.pelicanparts.com/uploa...1547216821.jpg I dropped it in the swamp first thing. It was half submerged for 30 seconds and it didn't kill it. I figure that's a plus. The puller weights about 12 pounds and gets heavy after a while. At 1000 pounds of pull, it's remarkably weak. The logs kept digging into the mud and I had to buck the 14" tree into 10 foot lengths to make the pieces light enough for this to drag it across the swamp. It has a 30% duty cycle - one minute at full load and two minutes sitting. I thought that would be very limiting, but it wasn't for me. It will retract the full 15' of cable in a minute and by the time I re-rigged it to another anchor point it was ready to go again. http://forums.pelicanparts.com/uploa...1547216821.jpg The battery lasts for about 3 hard 15 foot pulls. By hard I mean it was bumping up against the overload warning. It comes with 2 batteries that take about 2 hours each to charge. http://forums.pelicanparts.com/uploa...1547218089.JPG The thought of all that wood down there was eating at me until I began to think of it as more of a hobby than a mission to harvest firewood. I don't fish but i do enjoy being outside doing something useful and physically challenging. I could spend $400 on fishing tackle and spend afternoons catching $5 worth of fish, or spend $400 on this winch and spend afternoons harvesting $50 worth of firewood. I'll be doing something useful and getting my ass outside for exercise too. And it IS exercise, slogging back and forth through the swamp rigging and re-rigging the puller. The cable is 15 feet long and it took 3 15 foot pulls to get each log to the base of the ramp, where I could drag it up to dry land with my truck. In 2 hours I got two 14" by 30-40 foot long trees to the base of the ramp out of the ravine. |
You would be amazed at the logs that I have dragged out of tree lines, and across fields for bucking on my own proprty. I also have somewhat of a ravine that runs along my property (but maybe only 10-15 deep). I have always had good luck with a log chain thrown around the log, and clipped on itself like a choker, with the other end hooked to my bucket, and just yank it up with my FEL. My 30 HP JD 955 has 4wd, and many times, I have to add weight onto the rear draw bar to prevent lifting the rear wheels off of the ground.
As said before, "Safety First", don't stand next to an operating winch, or cable. If you can get near the logs, cut them 10' long and try pulling 1-2 up the hill using the rear draw bar hitch on the tractor, lifting it slightly to put more weight on the rear tires. |
Widebody911 you beat me to the Unimog suggestion! The winch I have on the back of mine has about 400' of 3/8" cable, and the front winch has 95' of 1/2" synthetic rope on it. So I use the rear for dragging logs out and pulling cars up onto the car trailer, and the front for when I get stuck!
http://forums.pelicanparts.com/uploa...1547238651.jpg |
It wouldn't get far, the couple of times I had my tractor down there I had to fold the ROPS to get under the trees, and that looks taller than the ROPS on my Kubota. But if you got to the base of the ramp and got turned, that 400' of cable would snake a lot of the wood up to the ramp so it could be dragged up. http://forums.pelicanparts.com/uploa...1547239949.jpg I'm sure you could get something that big down there. The first 100 feet would be easy. Then it gets steep and goes straight into the creek. I have to put weight in the bucket of the Kubota to get enough traction in all the mud and gravel to get up the steep part. You couldn't get between the trees on the side of the ramp with something that big. You would have to drive straight into the creek, get yourself turned 90 degrees, drive down the creek a ways, and back up into the swamp. |
Some amish may be able to pull them up with horses up top.
| All times are GMT -8. The time now is 08:24 PM. |
