-   -   Random welding tip (http://forums.pelicanparts.com/off-topic-discussions/1013691-random-welding-tip.html)
Shaun @ Tru6 11-21-2018 03:06 PM
Random welding tip
Making another dolly for a tub and the plastic lens on the outside of my helmet was in rough shape. That and don't use acetone to clean it. Had some 1/8" plate glass on hand so I cut a small pane out of it and and into the helmet. While you have to be a little more careful with the helmet, glass makes a huge difference in seeing over even brand new plastic. It was striking how much better I could see. Definitely worth the 10 minutes it took to make the glass lens.
http://forums.pelicanparts.com/uploa...1542841453.jpg
masraum 11-21-2018 03:23 PM
Here's another random welding tip!
https://www.millerwelds.com/-/media/...ig10000jpg.jpg
Shaun @ Tru6 11-21-2018 03:54 PM
clever!
dad911 11-21-2018 04:12 PM
Great welding. I've been trying to get one of these made, can you do it?
http://forums.pelicanparts.com/uploa...1542845306.jpg
wdfifteen 11-21-2018 04:16 PM
That’s one of Shaun’s, you can tell by his signature “S” on the top/bottom bar.
Arizona_928 11-21-2018 08:37 PM
I have a pack of clear glass 2x4.25 for my hood. Put one on the inside and out. The inside is overkill.
Matt Smith 11-21-2018 11:14 PM
When I first looked at this it didn't seem right. Then I worked it out: not enough penetration in the top of the 45 degree weld, left of picture. Did you run out of Argon?
