-   -   JD TRS-26 engine (http://forums.pelicanparts.com/off-topic-discussions/1014960-jd-trs-26-engine.html)
flipper35 12-06-2018 12:23 PM
JD TRS-26 engine
So, you cant get a replacement 9hp Tecumseh engine, does anyone know if any others will drop in? Like a 9 or 10 hp engine? There is a 10hp short block for $150 available. They have an odd two pulley system.
Looks like this:
https://assets.machinerypete.com/upl...arge_39464.jpg
http://manuals.deere.com/cceomview/O...37000_G876.jpg
asphaltgambler 12-06-2018 12:45 PM
You may be stuck as the rear of the engine case looks odd. Prolly to accommodate the idler / tensioner pulley assembly. If memory serves me with JD, they would only use whatever engine manufacturer and stick with it for small implements like this. I don't remember them switching suppliers during a run.
1990C4S 12-06-2018 01:13 PM
What's wrong with yours?
VincentVega 12-06-2018 01:18 PM
I have this bookmarked from when I was working on my snowblower
https://engine4less.com/All-Tecumseh-Horizontal-Crankshaft-Engines/
See if your SN falls in the range. Good for product details if nothing else.
flipper35 12-06-2018 01:55 PM
I wondered if another Tecumseh would drop in from another model.
VV, I will check the list there and see.
Dad has one with a cracked block and he is wondering if it is worth messing with.
1990C4S 12-06-2018 02:51 PM
Cracked block might be repairable.
I would rather fix the engine that fit than eff around with another one.
Or toss the snowblower...
93nav 12-06-2018 08:56 PM
Move south far enough that you do not need a snowblower.
Else, have you tried something like Small Engine Warehouse? SEW.
flipper35 12-07-2018 09:11 AM
According to the link above several have the same bolt pattern. Will let him go from there.
