-   -   A frozen pond question.... (http://forums.pelicanparts.com/off-topic-discussions/1015487-frozen-pond-question.html)
KFC911 12-13-2018 03:20 AM
What happens if a pond freezes over, and a substantial spring is still flowing into it? Will the cover of ice rise with the H2O?
oldE 12-13-2018 03:34 AM
If the outflow is blocked, you have two possibilities.
If the water feeds in under the ice, it will float the ice. In some cases, if the ice is frozen into vegetation, the incoming water will flow over the ice and if the temp remains low enough, a new layer of ice will form.
I've seen both happen.
Best
Les
KFC911 12-13-2018 03:48 AM
Thank you Les. No vegetation on top of any...I'm gonna try to see what's going on later with mine. Three ponds...spring under the largest (acre) flowing into another 1/4 acre...then another even smaller....via 4" pipes (with overflow pipes)....ice never entered my mind before...I'm southern :)
Haven't been able to see if my "engineering" is working...yet.
flatbutt 12-13-2018 04:56 AM
What kind of outflow is in place? Is it a spillway or does it have toe drains?
masraum 12-13-2018 04:59 AM
If the seal made by the ice is strong enough and the spring is week enough, maybe the spring will stop filling the pond and the water that would normally flow out of your spring will flow out of whatever other spring or outlet the water has (or even create a new spring somewhere.
I'm assuming your spring isn't the only outlet for the source and even if it is, water is capable of finding a new outlet.
cabmandone 12-13-2018 05:05 AM
I was thinking the same thing as Steve that the pressures would equalize and the flow would be reduced of not stopped altogether.
KFC911 12-13-2018 05:07 AM
On the largest...a 4" pipe, with a 10"? next to it.
Second one is a 4", inside of a 10"?
Last one is still more of a spillway, under construction...non-issue.
The outflows go from a garden hose on full blast (normal) to a fire hose (whole 4" intake under water) ....if that makes sense.
This storm has been a freak...never thought of this schit before.
KFC911 12-13-2018 05:08 AM
I have no clue....I need to dig out and go look ....
Thanks all!
flatbutt 12-13-2018 05:33 AM
So long as the ice doesn't block the outflow there should be no issue. If blocked then the rising water level will lift the ice as the ice floats on the surface. But if the ice gets too thick then ...I really can't say.
GH85Carrera 12-13-2018 06:21 AM
In North Carolina I can't imagine the ice will be super thick. I suspect it will just float up. If a concrete ship will float from simple water displacement, that ice will too. I just can't believe the ice will ever get so thick as to make a cap. Water will find a way out.
KFC911 12-13-2018 06:58 AM
^^^ I'm still trying to dig my truck out....started as a foot of snow topped with a nice thick layer of ice on top. I don't know if I'll be able to see what this thread is all about today after all...
This is VERY unusual for here before winter...even during.
....and a LOT of rain coming tonight/tomorrow.
cabmandone 12-13-2018 07:07 AM
Look on the bright side, if you wait till tomorrow all that snow and ice will be gone. You'll have another mess to deal with but the snow an ice will be gone.
Craig T 12-13-2018 07:38 AM
I love these threads. Interesting. It's like you are speaking in Latin to a Southern California boy. :cool:
masraum 12-13-2018 07:57 AM
Ice goes in cocktails, drinks and coolers. The idea that it could occur naturally outside of a freezer is pretty odd.
Craig T 12-13-2018 08:01 AM
Have you ever tried walking on it? I did once when I was a kid :eek:
Racerbvd 12-13-2018 08:52 AM
http://forums.pelicanparts.com/uploa...1544719779.jpg
CurtEgerer 12-13-2018 03:28 PM
If the pond is big enough (Lake Huron), and there's open water in the middle, and the winds are high enough ... this happens. That's not piles of snow. It's 25-foot tall piles of 10"x10" ice cubes, much of it winding up in people's living rooms. :D
http://forums.pelicanparts.com/uploa...1544743584.jpg
Jim Richards 12-13-2018 03:58 PM
It means you're in too cold of a climate, KC.
craigster59 12-13-2018 04:43 PM
<iframe width="560" height="315" src="https://www.youtube.com/embed/Qzt5Et4j6OA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Steve Carlton 12-13-2018 05:08 PM
If that extra water gets forced downward into a volcano, there's going to be a big explosion. Don't ask me how I know, because I don't.
