Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Porsche flat-six engine 1/4 scale model kit — noisy motor?
So, I got my flat six model kit together and it’s working as expected, but the motor is significantly louder than I expected, with a strained “whining” noise. Does this mean that I have something too tight in the drivetrain?
Those of you who have put this model together: does yours sound like this?
(Note: I’ve removed the fan housing and some other bits to get a better look at what might be going on)
https://www.youtube.com/watch?v=oa8JsDYVTCs&feature=youtu.be
Old 12-28-2018, 06:48 PM
DanielDudley's Avatar
Sounds like the timing chain tensioners. Honestly, I have no idea.
Spray some silicone into the cylinders. When I was a kid, I think some kids put the ''Visible V8'' together with vaseline as a lube. They never worked well, and they always sounded thrashy.
Old 12-29-2018, 01:59 AM
Slackerous Maximus
HardDrive's Avatar
That does not sound unusually loud for a plastic model being driven by an electric motor.
1992 Ducati Supersport. White frame, Ferracci pipes, open airbox.
Mercedes E350 family truckster.
2003 Mustang Mach 1....SOLD....now what?
Old 12-29-2018, 06:34 AM
cycling has-been
bkreigsr's Avatar
Be interested what the compression and leak down figures are??
Sounds like one crank journal is too tight.
Bill K
Old 12-29-2018, 07:15 AM
Groucho Marxist
Tobra's Avatar
Valve adjustment
The voices of Yoda and Miss Piggy were done by the same person.
Old 12-29-2018, 07:53 AM
gwood's Avatar
Carbon on the valves...
No, wait, that's on Ferraris.
Old 12-29-2018, 08:42 AM
a.k.a. G-man
Geronimo '74's Avatar
SSI and an M&K exhaust.
Made my car sound awesome...
Geronimo
32C Member #41
1986 911 3.2 Carrera (not stock)
1974 911 2.7 9114102230 SOLD
Old 12-29-2018, 10:02 AM
abisel's Avatar
My model makes the exhaust sounds of throttle blips much louder than the mechanical sound of the electric motor drive. Although I find it typical for a plastic geared model with no lubrication to be a bit noisy. Maybe a dab of Vaseline on the gears and bearing journals would help? Since this model required no glue, maybe you could take it apart and make sure the gears are installed in the correct orientation. And there is no binding with the main, rod, cam journals and the valves move freely in the guides.
Old 12-29-2018, 10:11 AM
Gon fix it with me hammer
svandamme's Avatar
muffler bearings are out of allignment
Stijn Vandamme
EX911STARGA73EX92477EX94484EX944S88NOW987C2007
Old 12-29-2018, 11:19 AM
Time for a full tear down, polish, balance, and blueprint.
Old 12-29-2018, 01:23 PM
Recreational Mechanic
Nickshu's Avatar
Must have a bad IMS.
Sent from my Galaxy S9 using Tapatalk
Current fun: 2004 911 GT3 - Trailered track only
Current Dailys: 2019 Ford F-150 Raptor / 2015 Volvo S60 Polestar / 2019 VW Golf R 6MT
Past fun: 2003 911 Carrera 2 Coupe (SOLD) / 1982 911SC Coupe (SOLD to a fellow Pelican) / 2005 Lotus Elise S/C (SOLD) / 1964 Corvair Spyder Convertible (SOLD)
Old 12-29-2018, 02:02 PM
abisel's Avatar
I don't get it. Why are 7 out of 10 replies idiotic replies? Someone goes to the forum to ask for some help on a plastic 911 engine model and he gets stupid replies. Come on people, we aren't like that when someone asks for help on a real engine. Give the OP a break.
Old 12-29-2018, 02:11 PM
Writer/Teacher
CJFusco's Avatar
Thank you for the (sincere) replies. I mean, the engine is functioning correctly — all the cylinders are rotating, the valves are opening and closing, the spark plugs are firing in the correct order etc — it’s just a little noisy. Since it took several hours to build, I’m not about to disassemble and rebuild again right now... but maybe it’s something I’ll do down the line.
Old 12-29-2018, 03:52 PM
chapo's Avatar
I dunno, my full scale one with megaphones is loud as hell! Sorry, I couldn't resist!
Patrick
Old 12-29-2018, 10:01 PM
Behind the Sun
Dump it
Put a 3.8
Never look back
Old 12-30-2018, 06:15 AM
Put some Slick 50 silicone lube in it.
http://www.bvdmotorsports.com
Active Rennlist Member.
http://members.rennlist.com/racerbvd/
See blog for my For Sale & Wanted List.
http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337&
Old 12-31-2018, 08:36 AM
You have been around for 18 years and don't understand the Off Topic forum?
Serious questions will get serious answers. A toy engine made of plastic and an near infinite reason to sound "funny" will get attempts at humor for replies. Some are funny, some are not so funny, but it is all in fun. No one really cares why his toy does not sound like he though it might. It is a plastic TOY or model of a real engine.
Humor or wise cracks and funny replies are the norm to not serious topics, and often to very serious topics as well. There are no real rules, except to not use profanity or pornography.
43 Year member of the Porsche Club of America
Old 12-31-2018, 09:12 AM
jyl jyl is offline
jyl's Avatar
Carrying on with the unhelpful theme, does this model make any provision for lubrication? Suppose you drilled teeny weeny holes and ran oil lines fed from the sump via a $10 pump? Might need to use teeny weeny beads of silicone sealant and Tri-X lube.
1989 3.2 Carrera coupe
1988 Westy Vanagon, Zetec conversion
Really want to find a clean E28 . . .
Old 12-31-2018, 11:07 AM
Deschodt's Avatar
I built the same with my kid. Mine is not quite as loud but neither is it super silent. I think as you suspect that you are hearing the electric motor a bit more than I am, because it is straining to rotate the thing (something a little tight in there)... I don't think I've run mine again since it was built - fun time though.
Old 01-02-2019, 06:30 AM
