beancounter
jwasbury's Avatar
Here's a shot lifting my 911 race car from the rear, using the jack bridge on the 4 post lift.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-19-2019, 06:38 AM
Puny Bird
Mark Henry's Avatar
A 4-post lift will give the same versatility, with a simple bottle jack. I think all 4-post lifts come with a sliding jack tray to lift the car off the ramps. I sometimes use the built-in jack points on the sides for wheel changes or brake work. Some even do engine removal with a 4 post.
Will it work? yes
Same versatility as a two post for working under a car? Not a chance.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-19-2019, 07:12 AM
aka 'vageen'
unclebilly's Avatar
Everything is a compromise.
A 2 post is better for working on vehicles.
A 4 post is better for storage and can be easily moved.
Both work fine for oil changes and exhaust work. For engine work and suspension work, a 2 post is better. Of course, almost anything that can be done on a 2 post could be done on a 4 post with some enginuitity.
If you need a hoist primarily for storage and need the ability to move it around, get a 4 post. If you need it for maybe a bit more than oil changes, get a 2 post.
76 930 - featured in Sept 2013 Pano
Yoosta have: 90 C4 Targa, 87 944, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche
Old 01-19-2019, 07:31 AM
beancounter
jwasbury's Avatar
Indeed. My 2 car garage is approximately 20’ x 20’ so while you could park 2 cars in there side by side, if you did there wouldn’t be room for anything else.
I could have fit a 2 post, but the posts would have been in a more obtrusive position for using the garage space as a workshop than where the 4 posts sit.
To get the wheels up for brake and suspension work takes a bit more time and thought than a 2 post. Also, when I want to work underneath the front bumper of certain cars, I need to park them towards the front of the lift so the bumper is overhanging the cross member, or else access sucks. No such consideration required with a 2 post. Still, for me, 4 post made the most sense for my space and needs. No regrets and I hate working on cars without it.
Old 01-19-2019, 10:33 AM
beancounter
jwasbury's Avatar
One other use I have found for the 4 post is unloading heavy stuff from my pickup. I drop the tail gate, set the lift ramps at the same level as the truck bed and back up so the dropped gate nearly touches the lift. Then you just slide the heavy stuff onto the lift, and gently lower it.
Did this for moving my tool bench and tool chest (both full of tools) into the garage, large pieces of furniture, and loading/unloading motorcycles from my truck.
Old 01-19-2019, 10:40 AM
greglepore's Avatar
Having had both, yeah, its obvious that you'd do a 2 if heavy maintenance was your primary goal, but the 4 post is dual purpose.
Greg Lepore
85 Targa
Old 01-19-2019, 02:16 PM
rnln's Avatar
stevej37, jwasbury,
Thanks guys.
Fat butt 911, 1987
Old 01-20-2019, 01:25 AM
Never banned
sc_rufctr's Avatar
Thanks for the input guys. I appreciate it.
I've been in contact with the vendor and I should have my lift in about 4 weeks.
Peter
Old 01-20-2019, 02:21 PM
rfuerst911sc's Avatar
Did you decide to go with the 4 post ?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser.
Old 01-21-2019, 05:16 AM
Never banned
sc_rufctr's Avatar
Yes, 4 post. My 911 will have the top bunk
Peter
Old 01-21-2019, 05:34 AM
rnln's Avatar
Plan on 1 or 2 roller jacks, or bottle jack as stevej37 and jwasbury mentioned above, to lift the car off the runways.
Fat butt 911, 1987
Old 01-31-2019, 10:30 PM
Did you get the memo?
onewhippedpuppy's Avatar
Pretty much everything has been said that I could add, except that if you want a trolley jack get it at the same time as your lift to save on freight. They are typically around $1000 and truck freight because they are heavy. I have a four post and agree with all of the pros and cons listed here, but I need to bite the bullet and invest in a proper trolley jack.
Matt J.
‘10 E63 AMG
Old 02-01-2019, 03:34 AM
I’m about to purchase a lift and despise reading all the pros/cons , I still can’t decide which lift would be better. Is there anything wrong with long term 2 post car storage for my 77 911? Who make wheel holding attachements for a 2 post?
Old 03-19-2019, 10:38 AM
Puny Bird
Mark Henry's Avatar
I say no, other than with both you need some type of drip tray if you're parking a car under it. This is easier to do (buy) for a 4 post.
Old 03-19-2019, 11:44 AM
scotricker's Avatar
No 2 or 4 post lift for me. I was thinking about it, and just now went out and looked at my standard 2 car garage, ha ha 8 ft 6" inside ceiling max.
So , and suggestions scissor lift or otherwise? I'm tired of jack stands
Scot
78 911SC coupe ..."my friends all drive Porsches, I must make amends.."
Old 04-25-2019, 12:39 PM
Rickysa's Avatar
Bendpak md-6xp (scissor) mid-rise has worked great for me...moving up to a 2-post soon
Rick
'88 Targa
Old 04-25-2019, 12:46 PM
Look on your local Craigslist and Facebook marketplace people selling scissor lifts all the time. Most lift 40 " - 48 " and can be moved around . I bought mine in my last house for 1K and I have seen them as low as 500.00 . They are simple in design so as long as hydraulic cylinder doesn't leak and pump motor works buying used is the way to go . I now have a 2 post and either one is light year's better than Jack stands .
Old 04-25-2019, 12:55 PM
greglepore's Avatar
Yeah, my house has 10 ft ceilings everywhere but the garage. I had a contractor "tray" the garage ceiling up to the rafters over the majority of the car profile. Works great.
If you just want one for maintenance, then I'd go with a set of quickjacks. I have a set from pre lift days and really like them.
Greg Lepore
85 Targa
Old 04-25-2019, 01:07 PM
Thread Killer
Teutonics's Avatar
Any recommendations on models or sources to buy from, with cost being a significant factor?
Or either of the above to avoid?
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 08-14-2019, 10:04 AM
Recreational Mechanic
Nickshu's Avatar
I have a Bendpak HD-9 with 2 bridge jacks. Love it. Had it for 3-4 years now. I wanted a 2 post originally but did not have the space for one. The 4 post w/ bridge jacks has worked fine for me. I would think about the only thing I could not do on it is an engine drop.
2020 Porsche GT4
1997 Porsche Boxster Race Car - SPB #94
Gone: 04 GT3, 03 Carrera, 82 911SC, Lotus Elise and other non-Porsches
Old 08-14-2019, 10:48 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
