Evil Genius
Rusty Heap's Avatar
130,000 pound Turbine Tank STUCK.
Your Curb weight +130,000 pounds.
you're stuck in the mud.
It's a Turbine Tank...............how do you "Punch IT " with a Turbine.?
https://www.youtube.com/watch?v=TCXwgPZXScM
M1 Abrams
Service history
In service 1980–present
Used by See Operators below
Wars Gulf War
War in Afghanistan
Iraq War
Iraqi Civil War
2017 Iraqi–Kurdish conflict
Saudi Arabian–led intervention in Yemen
Production history
Designer Chrysler Defense (now General Dynamics Land Systems)
Designed 1972–1979
Manufacturer Lima Army Tank Plant (since 1980)[2]
Detroit Arsenal Tank Plant (1982–1996)
Unit cost US$6.21 million (M1A2 / FY99)[3] Estimated in 2016 as US$8.92 million (with inflation adjustment)
Produced 1979–present
No. built approx. 10,288[4]
Variants See variants
Specifications
Mass M1: 60 short tons (54 t)[5]
M1A1: 63 short tons (57 t)[5]
M1A1 SA: 67.6 short tons (61.3 t)
M1A2 SEPv2: 71.2 short tons (64.6 t)
M1A2C: 73.6 short tons (66.8 t)
[6]
Length Gun forward: 32.04 ft (9.77 m)[7]
Hull length: 26.02 ft (7.93 m)
Width 12 ft (3.66 m)[7]
Height 8 ft (2.44 m)[7]
Crew 4 (commander/machine gunner, gunner, loader, driver)
Armor M1, M1A1: Burlington composite armor[8]
M1A1HA, M1A2: depleted uranium mesh-reinforced composite armor[9]
M1: Hull & turret –
350 mm / 470 mm vs Armor-piercing fin-stabilized discarding-sabot (APFSDS),
650 mm / 700 mm vs High-explosive anti-tank warhead (HEAT)[10][11]
M1A1: Hull & turret –
600 mm vs APFSDS,
700 mm vs HEAT[12]
M1A1HA: Hull –
600 mm vs APFSDS,
700 mm vs HEAT,
Turret –
600 mm / 800 mm vs APFSDS,
1,300 mm vs HEAT[9][10][nb 1]
Main
armament
M1: 105 mm L/52 M68 rifled gun (55 rounds)
M1A1: 120 mm L/44 M256A1 smoothbore gun (40 rounds)
M1A2: 120 mm L/44 M256A1 smoothbore gun (42 rounds)
Secondary
armament
1 × .50-caliber (12.7 mm) M2HB heavy machine gun with 900 rounds
2 × 7.62 mm (.308 in) M240 machine guns with 10,400 rounds (1 pintle-mounted, 1 coaxial)
Engine Honeywell AGT1500C multi-fuel turbine engine
1,500 shp (1,120 kW)
Power/weight From 26.9 hp/t (20.05
M1 Abrams
Production history
Designed 1972–1979
Specifications
[6]
M1: Hull & turret –
600 mm vs APFSDS,
700 mm vs HEAT[12]
M1A1HA: Hull –
600 mm vs APFSDS,
700 mm vs HEAT,
Turret –
Main
armament
Secondary
armament
Power/weight From 26.9 hp/t (20.05 kW/t) to 23.8 hp/t (17.74 kW/t)
Transmission Allison DDA X-1100-3B
Suspension High-hardness-steel torsion bars with rotary shock absorbers
Ground clearance M1, M1A1: 0.48 m (1 ft 7 in)
M1A2: 0.43 m (1 ft 5 in)
Fuel capacity 500 US gallons (1,900 l; 420 imp gal)
Operational
range
M1A2: 426 km (265 mi)[13]
Speed M1A1: Road 45 mph (72 km/h) (governed);
Off-road: 30 mph (48 km/h)[14]
M1A2: Road 42 mph (67 km/h) (governed);
Post–Cold War tanks
The M1 Abrams third-generation main battle tank named for General Creighton Abrams. Highly mobile, designed for modern armored ground warfare,[15] the M1 is well armed and heavily armored. Notable features include a powerful AGT1500 multifuel turbine engine, sophisticated composite armor, and separate ammunition storage in a blow-out compartment for crew safety. Weighing nearly 68 short tons (almost 62 metric tons), it is one of the heaviest main battle tanks in service
https://youtu.be/TCXwgPZXScM?t=10
Life is a big ocean to swim in.
Wag more, bark less.
Old 02-06-2019, 10:38 AM
craigster59's Avatar
When I was in the Army they had the M88A1 Tank Recovery vehicles. Man those things were slow and loud!
Old 02-06-2019, 10:50 AM
beatnavy's Avatar
I loved our M88. They were slow, loud, and a total beast (albeit a needy beast).
Dumb ass tanker should have called the recovery section (no offense intended to dumb ass tankers).
Rob C.
'72 914 2056
'75 914 Project
Old 02-06-2019, 10:57 AM
I think you punch it the same as any other gas powered vehicle.
The vid above embedded here.
Brent
Old 02-06-2019, 11:03 AM
