I'm looking forward to doing the restoration of the piece itself. It will neat to see it all clean and shiny again. It's one of those things that makes no sense financially but even running numbers still makes me smile. |
If you plan to remove it later, you should consider that in your design. With regards to the center post, take a look at how flagpoles are anchored to the ground. With respect to the fins, consider welding a flat base plate on the bottom of each fin that can be bolted to the concrete that you pour. When you move, that would allow you to unbolt everything, remove the center pole and off you go.
Thanks again for the suggestions! |
I watched them replace the street lights in our 'hood doing something similar. They had pre-drilled plywood forms that they mounted the J bolts to when they poured each of the footings for the new poles. They just supported the plywood on top of the forms so the J bolts stuck out the desired amount. Worked out well as the poles just slipped right over the J bolts without much trouble when they set the poles.
We call those anchor bolt templates, in the business. In my world, they are usually made from steel plate, but plywood also works for smaller projects like this. The idea is to place all of the templates in place prior to the concrete pour, so that you can verify the alignment, spacing and elevation/projection of the bolts.
It's a good idea for this project especially since he wants to be able to move it later.
The J bolts used on the light poles were @18-24" long if I remember correctly. I didn't actually measure them though. |
Any progress on the rocket?
By far my favorite playground equipment when I was a kid.
I haven't driven by lately but google maps still shows this one near my house: http://forums.pelicanparts.com/uploa...1602689420.jpg As I recall, they do sway a bit so I'd say the fins mounted in concrete is a must. |
Not sure if someone mentioned an epoxy based paint where it is stuck in concrete. I would do that.
I'll solve your problem by taking it off your hands, putting it in my backyard
Someone(baz I think) mentioned using Ospho as a anti-rust prep before painting.
A good choice after looking at vids. Once that structure has been cut at near ground level you have all the choices in the world to attach it to base. -Add reinforcements. -Add chamfers and corner brackets. -But treat any below ground metal first. |
Good score!!! You weren't tempted to just fly it over to the new site... |
| All times are GMT -8. The time now is 08:34 PM. |
