Another question for the help desk: VoIP related - Latency values
I recently installed a Magic Jack device for telephone service through my Internet.
Since day 1 - the audio output has been sketchy at best and on some days even non-existent. It's only a 1 way problem as I can hear audio perfectly - only the outbound audio is the issue. Using this speed test my values are: Latency: 41 ms DL: 28.1 Mbps UL: 9.45 Mbps 0% Packet loss The tech people over at Magic Jack are saying my Latency value is too high and that is causing the problem. They say the value should be under 25. I contacted my ISP and they say there's nothing they can do to lower the latency - it's a byproduct of my computer and configurations. I've swapped out phones and even replaced the Magic Jack and it didn't help. I have tried both connection methods - again - no change: https://www.magicjack.com/img/setup-...t-computer.jpg https://www.magicjack.com/img/setup-with-computer.jpg I was almost ready to try a different router but thought I'd run it by the brain trust to get some input, since this issue is way out of my technical skills. My router is a Netgear model WNDR3400 (N600) and I don't have any wireless devices hooked up - just the Magic Jack for my phone. TIA for any ideas or advice SmileWavy |
Mebbe someone "still in the game" will offer more than an old dino....but there is a LOT that happens on your device at the NIC, TCP stack, etc. that could be the culprit....something misconfigured at the router/switch....
If none of that makes sense....good....yer not a geek Baz :) Wait fer Scott or Steve or ???? My last corporate gig...5k VOIP conversions...I don't play dat no mo'.... T-Rex |
Thanks, Keith. We have a good assortment of technical folks here so I'm betting someone will have info that can help.
I woulda gone google voice through an Obi.
Well, actually I did do that, I meant if'n I were you... https://www.obitalk.com/info/googlevoice |
I'd still like to know about this latency thing though - and why I have poor or no audio output. Thanks, Scott. |
Who / what server did you ping that got you that result? Did you try others? Is your PC wired to the router or wireless? |
https://sourceforge.net/speedtest/ I did try another and it was similar. Ethernet cable - no wireless. |
Looks like this won't work if I want to keep my old landline number - I just did a check and got this message:
Try speedtest.net, run a couple of times using different servers.
My ping to them is roughly half what it was to sourceforge. Check your TCP settings. Ethernet should be Full Duplex. If it's not you can' transmit/receive (talk/listen) simultaneously. Meaning if not Full Duplex and the other end is noisy you'll never be able to be heard because you are stuck on receiving. Have you tried testing with a service like SKYPE? It's VOIP. |
Google can't port cable numbers. The way around that is you get a $10.00 prepaid phone card, slap it in a spare cell phone, port the number to that, wait a couple of days after the transfer is confirmed then port to google. |
According to the webpage - I can't even do the in between T-mobile trick - there is just no service in my area....period. |
I used Skype a long time ago and it was OK. Looking for something else. Be nice to get my Magic Jack issue resolved. I wonder if it's my router. |
15 ms on Speedtest.net.....less than half of what sourceforge had me at (41).
Turn off Auto Negotiate and set for Full Duplex. https://i.stack.imgur.com/Rq08t.png |
Is your area code 386?
Because google does distribute that area code. AFAIK, only Alaska and Hawaii are geographic issues with google voice. |
Just changed to Full Duplex and it didn't solve the problem. The Skype I had was like 10 years and 2 computer systems ago - so not sure if that means anything. I bought a new Magic Jack and the problem remained so can't be the device unless I have two bad ones in a row. Weird, huh? |
https://www.obitalk.com/info/tutorials/porttutorial |
Don't worry about it, Scott - you've done enough. You have better things to do on a Sunday night. One way or another I'll get it figured out. Thanks for all your suggestions and effort! I'll post again if anything new comes up...
MJ is full of sheisse about "25ms" being a requirement for VoIP. Cisco advertises a max of 150ms, and even that's BS. And Latency isn't that big a deal by itself. WHat is a big deal is jitter (how much the latency is bouncing around) and bandwidth in both directions.
You should have plenty of bandwidth in both directions. Latency is almost completely a function of distance. Latency is mostly (unless the network is heavily congested) a function of the speed of light (in glass which is lower than air) and the distance it has to go. |
I'll figure something out. There has to be something obvious I am not seeing. :rolleyes: |
Thanks for chiming in, Steve - really appreciate it. |
Steve is right that latency is fine, jitter is a big factor. Your bandwidth is fine, and so is packet loss. We do VoIP all over the world and even have some over 200 ms latency.
Are you trying to find cheap or replace traditional phone lines? Or both? We resell RingCentral and cannot say enough good things about their offering and services. |
My story on VOIP-
tried it at my office on the insistence of my network guy that it would make us more efficient and save money. well we had all manner of issues with it. at one point while diagnosing issues a third party says to my network guy 'we played back one of his conversations from the day in question and it sounded fine'. yep. they played back a conversation. my network guys had no idea that could be done. no more VOIP here. |
Latency could also be due to acks at the TCP or IP layers within the TCP stack itself OR on Baz's end exclusively and intermittent....unseen in "speed tests".... packet sizes, etc..
I am a systems/bit level guy....listen to SM....change course ;) |
A "ping" test does NOT test TCP....a different protocol and handled totally different behind the curtain...not a test at all in many cases....experience....btdt.
Another idea popped in mehead....check any settings you "might" have control over....TTL and memory, packet sizes, etc. at the TCP layer....it just might "matter" for VOIP....never noticed on PPOT :)
...or reread SM's first post ;) |
Were you having other issues recently, dns maybe? You said hardwired, no wireless right? Are you sure you have good connections? Try a fresh cable on a different port of your router/gateway. Might not be the issue but physical layer stuff gets overlooked a lot. Same goes for the connection into the house to the router/gateway. Cheap/simple troubleshooting step.
A few of the "best" I worked with...were gir.....err..ladi...errr....just damn good :). |
Agree with you VV - I'm going to pull everything and start from scratch to double-check all lines and connections. |
Apparently my problem is solved.
Let me start by saying I was testing the audio output all this time by calling my cell phone to leave a voice mail. The cell phone was not "taking" a message - and that's why I thought I had no audio output. Compounding things was I was having trouble with my audio output back before when my DNS specs were out of whack. So in my mind - this was just a continuation of the same problem. Where I went wrong with my trouble shooting was assuming my cell phone not "taking" a voice mail was absolute proof of the malfunction. So I decided before trying anything else, to call my oldest brother in Virginia this afternoon as a test and get feedback from an actual human being. To my surprise (and delight) he heard everything I said perfectly and we ended up having a 30 minute conversation. I should have done this a long time ago - but just assumed my cell phone should take a voice mail if the audio output was working - and I still don't understand that part of it - but overall - it doesn't really matter. Of course I feel stupid for all the time I wasted on trying to resolve a problem that was not really there - plus tying up others with a problem that was not really there. I guess what doesn't kill you makes you stronger? <shrug> So thanks to all who responded - it's greatly appreciated, as always! :) |
| All times are GMT -8. The time now is 01:16 AM. |
