-   -   Generator gas... (http://forums.pelicanparts.com/off-topic-discussions/1027415-generator-gas.html)
id10t 04-22-2019 08:17 AM
Generator gas...
So after Friday's pre-season demo and running my generator...
Do I drain and pickle like at the end of Hurricane season?
I'm expecting to need it again in the next 6 months... or not at all.
Leave the gas that is in it, add some Sta-Bil or SeaFoam and then drain and pickle at end of 'cane season?
Something else?
Thanks! Was nice having it start on the first pull when I needed it...
Deschodt 04-22-2019 08:24 AM
I'm sure experts will tell you... Personally I sta-bil what's left and let it run dry if there isn't much left. Or leave it with stabil but also run it a bit so it's all over the carb and lines for sure. I got tired of cleaning the carb/lines... If possible, I loan it to all my camping friends so it gets run several times a year.
Stabil really work - last time I did not use it, whatever came our didn't even smell like gas and it caused the mother of all cleanups..
expatriot98 04-22-2019 10:43 AM
Run it dry
Alfasrule 04-22-2019 10:57 AM
I shut the fuel line off and let her run till she dies and put stabil in the tank. Owned her for 15 years.
Used it twice.
Jims5543 04-22-2019 11:23 AM
I have an old gas generator that I have had since the 90's and still runs great and never a carb issue.
Another +1 on run it dry, I take it a step further, after it runs dry and cools down, drop the float bowl down, empty it and dry it out. Leave it off for a few let any residue evaporate.
Reassemble and store it away. I give mine an oil change before storing it.
Chocaholic 04-22-2019 11:28 AM
All the above but about once a quarter I start it and let it run for 10 minutes. Shut off fuel valve and run it out of gas and put her away.
rfuerst911sc 04-22-2019 11:32 AM
Put Sta-bil or the brand of your choice fuel conditioner in the tank . Start the generator and run it for 10 - 15 minutes you are trying to make sure the fuel conditioned gas is fully in the carb . Then turn the fuel shutoff off and let it run until it quits . This gets rid of 95 % + of the fuel in the carb and what little is left over has the stabilizer in it . Start the generator every 3 months but go through the above shut down process . I doubt you will ever have a carb issue going this route .
KFC911 04-22-2019 06:01 PM
Ethanol gas...run it dry. Otherwise Stabil....jmho.
carreradpt 04-23-2019 10:47 AM
Living in hurricane country, I break out the generator and run it once a year. Always with non-ethanol and run it for a while with/wo loads until it runs dry. I don't keep much gas around but it is always with sta-bil. Always a one pull start.
1990C4S 04-23-2019 10:51 AM
I would run it dry on some two stroke mix. Works on my snowblower.
