Can anyone tell me if its possible to remove the sender unit on a 964 C4 on the gas tank to inspect the contents?
On my '88 its possible but can't tell by the pictures in the Bentely Book. Also I'm thinking of leaving off the engine cover, the one under the car for the trip home. Any advice on this would help. |
http://forums.pelicanparts.com/uploa...1557504924.jpg http://forums.pelicanparts.com/uploa...1557504924.jpg |
https://www.pelicanparts.com/techarticles/Porsche-993/48-FUEL-Fuel_Level_Sending_Unit_Replacement/48-FUEL-Fuel_Level_Sending_Unit_Replacement.htm Regards, |
I’d keep the engine cover on the car, as long it’s in good condition.
Sounds like an awesome adventure! I’d probably also drain the fuel, replace the pickup sock, and change the fuel filter. 5 year old gas is no bueno. Also don’t be surprised if you have leaks, but most of the lines are just bulk rubber hose from the closest FLAPS. Though it might be cheap insurance to buy the premade hoses that mount in the engine bay. Also I would grab an automotive fire extinguisher from the nearest Walmart just to be safe. Ethanol fuel is hell on old cars.
Good idea on the fire extinguisher. How does one inspect the pick up sock?
This is just what I needed. |
Has the car actually been sitting idle for multiple years? If so there’s a risk of one or more brake calipers being frozen up. Not much you can do in advance but something to check ASAP. You can always have a rebuilt caliper shipped in overnight if necessary. I would definitely take it easy on the brakes to start, and if it pulls under braking that might indicate a caliper that isn’t deploying and is frozen in the bore. Might also consider a brake bleed if tools permit.
I am going to flush the entire brake system before the trip.
I would drain and fill the transaxle too, maybe have some spare fuses, relays and what not too.
| All times are GMT -8. The time now is 02:47 PM. |
