Banned
cracked, my cast iron skillet
My Wagner 10 1/2" skillet has developed a crack. I have no idea how, age?
Anyway, are they now mostly the same, I see Wagner still makes them, go with them or something else? Yes, I know there have been threads on these but I didn't pay attention then, I didn't need one. |
Used is always better if in decent shape. Our old CI stuff is so slick with carbon that it looks like Teflon. If I had a new CI pan I would have to massage on it in the shop until it was ready to season.
Hit up garage /estate sales for Wagners and Griswolds. Lodge is good for new or you can bite the bullet and buy vintage... https://thepan-handler.com/product-category/newlistings/
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
No to the new Wagner. The name was sold long ago.
I would find a new vintage pan or buy one of the newer pans made by companies using the old techniques. Neither option is super cheap. Sorry for the loss; that would suck.
poof! gone |
Scott '78 SC mit Sportomatic - Sold |
Can it be welded with nickel rod?
Banned
Looks like I better start hitting up the second hand stores, I have seen them but like I say, never cared before. I don't even know when I got this one, I just always had it.
Banned
don't know about the welding but I thought about it. Welding Cast Iron, the crack goes all the way across.
There used to be a cast iron acetylene rod that was square, about 1/4 square from memory. It was made for repair of old cast iron pots. Maybe it still exists.
Dill a hole at the end of the crack to keep it from growing, preheat the whole area and then weld to the hole.
drew1 wife has 924 turbo |
Unregistered
Welding cast with ni-resist rod is not a molecular bond, just a physical bond. Won't stand up to heat cycles and you probably couldn't get the base metal clean enough anywho.
Go down to wally-mart and plop down a $20 spot and get a brand new 12" skillet, pre-seasoned. You won't notice the difference after a few uses. https://www.walmart.com/ip/Lodge-Logic-12-Skillet-Seasoned-Cast-Iron-L10SK3-with-assist-handle/5969633 ![]() Quote:
Go to estate sales. They always have a few cast iron skillets. Usually for very cheap.
A Man of Wealth and Taste
I have a couple of really old pans made in the USA that are no name that I got in South Carolina. When I got em they were really crusty, i burned em to clean. Now they need seasoning. One is 10 and the other is 8 inches.
Let me know and I will take pictures. 20 each plus ship. To Cali from here apx 10 for one. It's the weight that gets ya.. |
The old pans are smooth inside The new ones are rough and grainy.
Or you could buy Le Creuset...i recently found a perfect 12 inch blue one for $8. As a matter of fact i have been finding quite a few Le Creusets recently. A 7.5 qt French oven, a 12 inch Au Gratin and a 10 inch Grill pan. Last edited by tabs; 11-06-2018 at 07:25 AM.. |
oh boy! buy that one from TABS.
my favorite cast iron is a 10" no-name. it's great. i bought it from some hoarder that had thousands of vintage pans.
poof! gone |
I also have an extra Wagner 8 inch...
I cracked one a few years back...too hot and put in a cooler pork chop. I heard it snap and thought it was done. I have continued to use it to this day with no real issues
1986 3.2 Carrera |
You do not have permissi
That is what random orbitals are made for.
![]() (rough on the bottom might help absorb more heat. IDK.)
Meanwhile other things are still happening. |
I have a new Lodge with the rough surface, and a really old smooth Wagener. They both work great. People bad mouth the Lodge brand/type, but its been non-stick from pretty much day one. I love it. Its just a hunk of heavy metal. I think people way over think it.
Banned
The way I found this crack was when I put a table spoon of oil in it to cook something it seeps through the crack into the burner. If I was just cooking pancakes I doubt I would notice it.
