Bill Douglas's Avatar
Who has used an electric chainsaw sharpener?
I'm thinking of buying this thing ToolShed Electric Chainsaw Sharpener - The Tool Shed as I do a really bad job of sharpening chainsaws by hand. Do you have an opinons on it?
Old 05-18-2013, 08:42 PM
non-whiner
mreid's Avatar
Just buy a new chain.
"Too much is just enough."
Old 05-18-2013, 08:59 PM
Chains get sharpened about 20 or 30 times in the lifespan of a chain.
Old 05-18-2013, 09:06 PM
Bill, those things are great. I have a similar unit manufactured by Oregon. I have also used a Dremel with the chainsaw sharpener attachment...
Old 05-18-2013, 09:09 PM
Baz. By Oregon. That would be good. I only use Oregon brand chains and these guys know their stuff. When I'm sharpening by hand and using a guage I still take too much off one side - just not right when I do it.
Old 05-18-2013, 09:17 PM
I agree, Bill.
The advantage of using the Dremel method is you can leave the chain on the saw while sharpening. Time saver.
I have both but find myself using the Dremel more just because it's faster. It works pretty good too.
Old 05-18-2013, 09:21 PM
Professional Bull5hiter
Outback Porsche's Avatar
Best money I ever spent. Cutting mulga, I need to touch the chain between each fill of the tank or I'm buying more than just a new chain. That 5hit will dull a chain in no time which will lead to the bar over heating and burring over. A bar will only dress so often. I cut about four tonne of mulga every winter.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 05-18-2013, 11:11 PM
Bill, I have one. It works great.
Old 05-18-2013, 11:53 PM
So it works something like Baz's dremel and has gauges etc?
Old 05-19-2013, 12:45 AM
wdfifteen's Avatar
That type (first photo) is great. I've sharpened dozens of chains with one, though I've never used on with the bike brake handle - I guess it clamps the chain in place? You just need to keep the stone in shape and set up the depth correctly. Does it have a flat faced or concave stone for grinding the drags?
Old 05-19-2013, 04:03 AM
fred cook's Avatar
Plus 1 for Dremel
I agree, Bill.
I use a Dremel chain sharpener also. Works great w/chain on the saw!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-19-2013, 05:42 AM
Drisump's Avatar
The rig on the original post looks kind of cool but I don't think you'd likely take the chain off the chainsaw and run it through the rig at the appropriate intervals. So I'm thinking that a guy would likely run it until it was burning through the wood, as opposed to cutting it. Guys that use chainsaws all the time, and I do very often, give the chain just a couple of strokes of the file every fill up. In the process, they count filing strokes to maintain an even tooth over the whole chain. My concern about using the Dremel all the time is, although you end up with sharp teeth, you could potentially end up with a chain that has a wide variety of tooth sizes. When the chain has some teeth that are smaller than others, you can't cut a straight line. I think most occasional users run the saw until it can't cut butter and then start filing like a maniac to get some cutting action. Also when a chain gets to a certain point you need to file down the "raker" part of the chain to allow the chain to take a bigger bite. I've used a Dremel tool to take down the rakers and sometimes to get a little more life out of a thrashed chain, but typically if you file it lightly every fill up, it won't get out of hand. Cheers
Old 05-19-2013, 07:26 AM
vash's Avatar
i just use a hand file and eyeball it. the file really can only fit one way, one direction.
but i dont chainsaw very often. you firewood burners are really commited to the cause
poof! gone
Old 05-19-2013, 08:31 AM
Scott R's Avatar
You guys have a lot of free time, I dropped mine off on Thursday and it was done Friday for $7.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-19-2013, 09:24 AM
Don Ro's Avatar
Like others, I use the Dremel with the correct size stone.
Be mindful to not get the cutters too hot.
You can use a file gauge to cut down on the rakers...I just rub them a bit w/the spinning Dremel stone.
Works for me.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 05-19-2013, 10:02 AM
The idea behind the sharpening device in the OP is that you get more accurate, uniform, sharpening action. And it's really quick to use.
Old 05-19-2013, 10:04 AM
LakeCleElum's Avatar
My neighbor has one of those.....I cut circles around him....I have my truck full while he's screwing around trying to sharpen after cutting 4 or 5 rounds....
I keep 5 chains I have sharpened for $6 each at a shop...One chain can last me all season thru 4 or 5 cords...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-19-2013, 10:23 AM
wdfifteen's Avatar
As drysump said, you hit the cutters with a file every fill-up, and every now and then take it in to someone with a rig like that in the op (more likely a professional version of the same thing) to get the cutters back to even and cut down the drags. You KEEP the chain sharp, you don't run it until it's smoking and then try to sharpen it.
Old 05-19-2013, 10:48 AM
5 chains? I think you need to buy a sharpener like your neighbor's. Do the math - you're buying a new chain at least every month.
One of the things that I do is own and run a Christmas tree lot every Nov-Dec. Its part of our larger operation. We sell around 1,400 to 1,500 trees each year, and run one saw. I have three to four chainsaws on site, but we really use just one saw. One chain lasts all season. We just sharpen the chain and don't run it in the dirt or run it too tight or dry.
Old 05-19-2013, 11:07 AM
I use a 12 volt sharpener. Works great. Ablut 19.00.
1990 Wanderlodge PT-40
75 911S Silver Anniversary
1952 MGTD
1983 Mercedes 300 TD
1969 Lincoln
Old 05-19-2013, 11:26 AM
