What’s this wire near my gas meter?
Ok boyz
I got a fresh gas line and outdoor meter about 2 years ago. Works great, never look at it. But Here’s a stranded yellow wire, I’d say it’s 12gauge. Comes from the street-side of the gas line and to the meter and looks like this. What is it? Did they just run it with the new line for future needs or something? Or is it a job that got overlooked? Cheers http://forums.pelicanparts.com/uploa...1559839312.jpg http://forums.pelicanparts.com/uploa...1559839312.jpg |
Probably the locater wire to trace the gas line location.
Tracer wire to located the gas line underground
2 correct answers^^
Yes, tracer wire - because your gas line is non-metallic and the metal inside the wire can be picked up by a locator, if needed.
Around here, they also lay yellow colored plastic tape on top of the pipe so it gives somewhat of a indicator/warning to anyone who is digging where the line is buried. |
Fuse!
Wiley Coyote style!!! Yep. Tracer wire doesn’t seem so exciting now, does it? |
Yep, tracer wire. Just wind it around the post, and to make it look nice, maybe use a zip tie to hold the wire out of the way and against the gas line. Then hit it all with grey paint to match.
Didn’t read the replies, but it’s a tracer wire.
JK 🤪 |
I just know I closed my eyes and said a prayer before I cut the one off mine years ago ....
PPOT didn't exist then ;) |
tracer wire used by the Deep State to blow yer azz to hell if you monkey with the power structure
Yep, it's for intel. THEY know where your gas lines are, the bastages. There's probably one in your toilet too. |
So You guys say I’m supposed to tie it in to one of the buss bars in my panel?
Awesome! This place has all the answers Thanks! |
Not if you cut it. Do you still have toilets inside? Focus man, focus...
Like for a 9 volt battery, test it for voltage by sticking it on your tongue.
It’s a secret listening device. And a tracer wire.
Its actually 14 Gauge Tracer Wire, if dinner conversation was lacking one evening.
My "how I deactivated the meter IED" story is NOT boring...to me....imo ;)
metal pipe?
why a tracer wire. also a bit heavy ga for tracer wrong color for ground wire.. I have tracer wire on some fiber at work, much smaller if I remember correctly not saying its not tracer, |
yes, I know what a tracer wire is.
I have fiber that I have to locate for work using a tracer. that tracer seems kind of thick, most companies want to go cheap and put in a thinner ga wire. are you sure it transitions to plastic. they may want it metal so local home owners cant break it to easily. did not know it transitioned to plastic. |
It’s a tracer wire installed by the plumber and required by code. It is what Dig Alert or any other underground utility located uses to find the plastic, yes plastic, gas lines underground. This is not a mystery or conspiracy, read the plumbing code or call the utility company. The size of wire is dictated by code.
ok.
just seemed a bit odd if it was metal pipe all the way. |
Answers a question I have had since gas line replacement. The knowledge here.........
| All times are GMT -8. The time now is 03:00 PM. |
