Why not convert to salt. Best thing I ever did. Once you add the initial amount pretty much done
Agree. I've been swimming all my life and the saltwater type is so much better.
If you haven't compared the two, try one out. |
I have been looking at all sorts of ways to chlorinate my pool and I am going to convert to saltwater.
Connect it to Azure and use IoT sensors to measure the chlorine so it can adjust the dosage. :)
I'm considering a SWG. I was told to buy a system roughly twice as large as needed so I'd need a about a 40K setup (pool is 18500 gallons). The price doesn't bother me but I was told to figure on replacing the cell every 5-7 years which is another 4-$500 and I'm not sure if there isn't a bit more maintenance to a SWG than there would be to my dosing system. As to softer water, I put about a bag of pool salt in my pool (scatter it around the pool over a few days) so the water is soft. No dry skin for me or my kids!
Sell your house to someone that has never had a pool before. Buy a new house without a pool. Get your life back.
I figure building the dosing system just eliminates me walking out each nigh to add the chlorine. I don't get why people think a pool is so much effort and time? |
My reply was mostly tongue-in-cheek, if you didn’t get the humor. |
I figured it was intended that way. Kinda like the two happiest days of a boat owners life.
After 4 seasons, I need to replace the valve which controls water flow through the chlorinator. Otherwise its a simple and effective liquid chlorine dispenser for your pool. |
I'm on my 3rd or 4th season with the Liquidator and the valves are ok but one of the tubes connecting the John Guest fittings went hard and started sucking air causing my pump to lose prime. Instead of replacing all the plumbing I'm going to a Stenner dosing pump and 15 gallon storage tank. I will be nice to be able to store chlorine in the tank and only fill it once or twice a season instead of pouring in bottles every other day or so.
https://www.poolweb.com/media/catalo...4STAA-img1.jpg |
I looked at various systems. By the time I bought and put everything together, the cost for liquid dosing would be around $500 plus the cost of liquid chlorine per year. The SWG is going to cost around $700 including the controller. I will need to buy about $250 worth of salt.
I was using tri-chlor. I have to drain my pool and refill because of the stabilizer buildup. I think they are designed for "northern" pools that only run 3 months, never get too warm and are half drained every year. Don't use on year round pools! I am presently using cal-hypo 3" tablets which are fine, but are kicking the hardness up, which is fine as I started "low" on purpose. Cost is about double that of Tri-Chlor. I have a 45 days supply of cal-hypo, and expect to switch to SWG by the end of July. |
I’m actually starting the season on Trichlor this year because I need to increase stabilizer level anyway. |
I only use the "pucks" or the tablets when I'm going on vacation. I typically don't add any stabilizer until after I get back from vacation because the tablets add CYA (stabilizer). I normally check and add stabilizer to get to the recommended level (around 40 ppm IIRC) and leave it alone after that. No draining and filling, just have to add chlorine. The SWG's seem like a nice way to go from the reading I've done. My problem is, for this year I'm already all in since I bought my chlorine for the season.
Will, I considered going the stenner pump route but those things get expensive based on the searching I've done. By the time I buy a stenner and tank setup it looks like I'm fairly close to the cost of a salt water generator. |
| All times are GMT -8. The time now is 09:19 PM. |
