-   -   Help me with my breaker box (http://forums.pelicanparts.com/off-topic-discussions/1034885-help-me-my-breaker-box.html)
RWebb 07-17-2019 11:14 AM
as I understand the Federal Pacific problem, it relates to the Stab-Lok circuit breakers
here is the first hit I found on a search (note the fraud part):
https://www.angieslist.com/articles/are-federal-pacific-circuit-breaker-panels-safe.htm
Baz 07-17-2019 11:41 AM
My house has the same breakers - I'm sure they are original from '62 when the house was built.
Been here 23 years this month and have had no issues.
I do plan to upgrade it to a bigger and better quality component panel --- but not because the homeowner's insurance company says I have to.
Got rid of them when I paid the mortgage off 4 years ago.
Good luck - stay safe!
red-beard 07-17-2019 11:51 AM
Aluminum wiring article
https://en.wikipedia.org/wiki/Aluminum_building_wiring
Note, that post 1975, the aluminum is different and poses no risk.
PD41 07-17-2019 12:04 PM
Here in So Cal 1st thing is to call your electrical provider for a location inspection to see if the existing location is acceptable. Called a spotter. Sometimes the existing location is not acceptable. They might want the new panel closer to the power pole or on the other corner of the house.
This can affect the price of the job if the panel needs to be moved.
Most circuit breaker manufactures give breakers a 7 - 10 year life span.
Many older houses have 20 - 60 year old breakers.
PD41 07-17-2019 12:06 PM
Aluminum wire always gets loose on receptacles, causes arcing and fires. No Good.
red-beard 07-17-2019 12:07 PM
Not true. The early wire does. But the post 1975 alloy wire has the same mechanical properties as copper.
MBAtarga 07-17-2019 12:16 PM
I agree the panel needs to be replaced - and all of those current breaker values need to be reassessed.
If the landlord is going to address this problem - then you can ignore the suggestion below.
But if you're going to investigate this further, do yourself a favor. Before you start opening up outlet covers and checking wiring, go buy a GFCI tester and plug it into your suspected circuit outlets. It will automatically tell you if there is a short or an open that would likely be causing the 30A breaker to trip(if the breaker itself is not faulty.)
http://forums.pelicanparts.com/uploa...1563390888.JPG
Pazuzu 07-17-2019 12:23 PM
Originally Posted by red-beard (Post 10527318)
When was house constructed? Aluminum was only used for a short period for house wiring.
I know several electricians that can replace the electrical panel with a modern one. If you are inside City Limits, it will take an electrical permit
1950, which appears to be pre-aluminum. I'm far less concerned about the wire than the general age of the house.
Tell me this though, does that work if the breaker is tripped? I'd assume that you need some power flowing, but maybe not? If those work with the circuit de-energized that I'll sure get one just to add to my collection of tools and testers...
red-beard 07-17-2019 12:47 PM
Good, this is a non-issue.
The tester will only work on a live circuit.
red-beard 07-17-2019 12:49 PM
BTW - The failure issue with the FPE breakers is they stay closed when the circuit overloads.
URY914 07-17-2019 01:13 PM
We were looking at a house with aluminum wiring a few years ago. Insurance broker could only find one carrier that would write a policy for it. It was a deal breaker for us.
911 Rod 07-17-2019 01:16 PM
Originally Posted by Pazuzu (Post 10527042)
OK, but what about when me, HappyHomeowner, plugs in 25 amps of stuff on those various outlets, unaware that for whatever reason the kitchen, livingroom and front porch are all connected.
I understand what you're saying, and I'll downsize the breaker to 20amp, but it just means that *I* need to be aware of the limitations of that particular circuit from now on, right? Hell, I used to run the electric lawnmower on that circuit, now I know that if I do that, I can't have the microwave on at the same time, or the livingroom A/V system running. I probably did damage to it by mowing the damned lawn...
Not sure if you should be doing electrical work ....
Pazuzu 07-17-2019 08:09 PM
Ha! That's funny!
I might have been unclear. I, as the unknowing homeowner, could very easily have put more than 20 amps of load on that breaker without knowing it. What with a microwave on one of the kitchen circuits, and the TV/receiver/subwoofer/cable box on a surge protector on one of the livingroom circuits, then a lamp on another circuit, then the Christmas lights on the outdoor circuit, along with the flagpole lamp, and then maybe the leaf blower.
Seems like a single 20 amp breaker is too SMALL for the total number and distribution of outlets that it's connected to. Seems like it should be 2 or 3 20 amp breakers feeding those same 7 boxes/14 outlets.
dad911 07-17-2019 11:09 PM
Current electric code would not permit that mix of receptacles. Now kitchens get at least two 20 amp circuits, living room would be on a different circuit, as would exterior GFI .
In any event, you don’t add the loads to size a breaker. You size the breaker to the wire, and distribute/add circuits as needed.
