fastfredracing's Avatar
Back down a torque wrench that is in constant use ?
Just wondering. I know you are supposed to wind down a torque wrench for storage , down to its lowest setting .
I of course have good wrenches for motor work etc, but also have wrenches that I basically only use to torque wheels, and maybe steering knuckles .
I use it constantly, it probably torques 100 fasteners a day . I find my self constantly winding it up and down.
Most everything I torque is right in the range of 85-110. My older one just failed, not the head, but the mechanism that sets the torque . I think it just wore out, from being turned up and down 10 times a day , 6 days a week, 52 weeks a year etc....
I think I am just going to leave my new one set at 100.
The longest it ever sits , is overnight .
No left turn un stoned
Old 08-08-2019, 12:59 PM
I'm a novice, and my POS Craftsman is toast...'cause of that...
Leave it alone...yep.
Old 08-08-2019, 01:07 PM
Eric Coffey's Avatar
Maybe look into getting a few pre-set torque wrenches for your most commonly-used values.
Still Doin Time
asphaltgambler's Avatar
If you use it frequently during the day, leave it where it is until the next job - I would set it to MIN when putting it to bed overnight. Yes even good torque wrenches lose their range. I have mine calibrated / adjusted once a year.
Old 08-08-2019, 02:40 PM
908/930's Avatar
In your case probably better to leave it set, it should take a long time for the spring to loose its set tension. You can always check it after some time against another calibrated torque wrench to verify.
Old 08-08-2019, 04:14 PM
I back the down because I do not use them every day. Harbor Freight one just does wheel and Snap On for real work. Thought about getting one of these, Just turn a ratchet into an instant touque wrench.
https://www.amazon.com/Performance-Tool-M206-Digital-Adapter/dp/B00EDEDKHE/ref=sr_1_2?crid=3FFBF0GEYO1Z3&keywords=torque+calibrator+tool&qid=1565306948&s=gateway&sprefix=torque+ca%2Caps%2C178&sr=8-2
Old 08-08-2019, 04:33 PM
Brew Master
cabmandone's Avatar
When I get my torque wrench out it normally stays at the torque setting until the end of the day. I back it down when I put my tools away at the end of the day.
Nick
Old 08-08-2019, 04:37 PM
Evil Genius
Rusty Heap's Avatar
I back down my T wrench every use.
and don't slam Craftsman, at least MY wrench.
I worked at Boeing Cal Cert Tooling dept.
it was withing 5-10 pound of spec control compared to snap-on.
Note. Boeing has 6 FOOT long torque wrenches for tightening the 3 NUTS that hold the engine onto the pylon.
Life is a big ocean to swim in.
Wag more, bark less.
Old 08-08-2019, 04:44 PM
D idn't E arn I t
RANDY P's Avatar
Certain ones don't need to be backed down- Precision instruments / Snappy with the little knob on the side used by tire shops comes to mind.
If it's one that has the old handle you turn (HF has 'em everywhere) then ya, undo it.
AOC/Hogg 2028
Old 08-08-2019, 05:08 PM
AutoBahned
RWebb's Avatar
only spring types need to be "backed down" as leaving them tight puts a "set" on the spring (alters k, the spring constant)
the digital types use a load cell and do not need this (generally more accurate too) - I bought some used Snap-Off ones on evilbay
the beam type ones 'back off' on their own
Old 08-08-2019, 05:17 PM
D idn't E arn I t
RANDY P's Avatar
This thread reminds me.. I need a 3/8
Problem solved
AOC/Hogg 2028
Old 08-08-2019, 05:25 PM
Why would you not use a digital one?
Old 08-08-2019, 07:00 PM
I will trade you . Purchased after I acquired my 911 years ago, and backed down after each use. The cheap plastic locking thingy is frozen, and of course Craftsman quit "standing behind" their products by then/now. That's the one I used the most....but not even broken in before it broke really .
Old 08-09-2019, 02:57 AM
Just bought one almost $800.00. I keep that in its case, in my safe deposit box at the bank next to my last will and testament .
Cant bring myself to use an expensive one to beat around the shop all day torquing pick up truck wheels , and I guarantee that a cheapo digital will be broken in 6 months.
Old 08-09-2019, 04:51 AM
pete3799's Avatar
https://www.matcotools.com/catalog/product/TLS788/10-piece-torque-limiting-extension-set/
Pete
79 911SC RoW
Old 08-09-2019, 05:53 AM
Zeke's Avatar
A beam TW was mentioned. Why not that for lug nuts, etc.? Close enough.
Old 08-09-2019, 08:04 AM
Do any of you have good ones for inch-pounds?
Old 08-09-2019, 08:53 AM
devodave's Avatar
Dial torque wrench
We only used Sanp-On dial torque wrenches when I worked at the shipyard (Norfolk Naval Shipyard), mainly torqueing fasteners for pipe flanges as a pipefitter (both non-nuc and nuc systems). These, like beam types, do not have to be relaxed after use and give you an idea where you are at in the torqueing process. Always use at 1/4 to 7/8 of the scale. A 0-175 ft-lb is currently listed on e-bay for $125. I much prefer the dial type to the clicker type myself, but that's was I basically cut my teeth on.
David Gray
71 Gemini Blue Metallic 911T
Old 08-09-2019, 08:55 AM
Park Tool USA - From a bicycle shop etc. Beam type
Old 08-09-2019, 08:57 AM
