I prefer one of the rubber tapes. |
This is the first I've ever heard of capping the joists of a treated lumber deck.
I'd use the butyl tape if I was doing it over again. It will damp a loose board too. If I lived in a hot, wet area like the OP I'd do the tape for sure. Copper is nice but it costs... |
I will note that here in the Pacific North Wet I have moss regularly growing on the sides of the decking. :-/ I expect that less wet areas would benefit less from copper than my location. When I built 20+ years ago, I had no knowledge of any capping products on the market. Not liking the nasty chem of pressure treated joists of the time, I went with cedar and laid out my own joist caps with copper. In between the joists I fab'd up some SS pans. This combo gave/gives me dry space below the deck. It's held up great. I've never used the tape, but looks like it doesn't do much to protect the joist sides. |
Like many of us I fall into the " while I'm in there " on most projects :D . It's been a while since I have done a decking project so I started looking at DIY websites to see if anything has changed or to look at suggestions on how to make a better mouse trap ;) That's where the idea of covering or shielding the top of the joists came from . Looking at the support structure of the deck from below it looks to be sound with no visual indicators of any problems . The joists are straight with no discernible sag . They could use a pressure washing which I will do before tearing up the 5/4 boards .
If I am going to go through the trouble of tearing up every board and replace NOW would be the time to cover the joists IF I am going to do so . I want this replacement to be the last one I do in my lifetime ! I can see where the butyl tape has merit for sealing around screws and adding some cushion , but because it is basically the same width as the joist it doesn't add any " water shedding " to the sides of the joists . Paul's idea of cutting roofing tar paper 6 " wide sounds like a winner to me , being 6 " wide once stapled in place gravity will " drape " the paper on each overhanging side . Any water that runs/drips down between the deck boards will be shed away from the sides of the joists . Cheap and effective sounds like a win win to me :D The only reason I am in this position of replacing the deck boards is the previous owner was too cheap or lazy to maintain them :mad: so now I have to clean up the mess . The first major decision I have to make is composite vs. pressure treated . Each has pluses and minuses , the other day I checked out what I consider to be good quality oil based semi transparent stain and it runs $50.00 a gallon ! Multiply that times the amount of gallons needed for this large deck then multiply times redoing it every 2 - 3 years has to be figured into the equation . I am fortunate there is a pressure treated wood manufacturing facility near me so good quality pressure treated decking is available and the initial install price is much less than composite . But then figure in the maintenance/upkeep and the cost to composite shrinks . But there are so many horror stories out there about composite about it sagging/staining/scratching/expanding due to cut edges not being sealed that scares me also :D I am going to do something fairly soon just don't know what that is yet . Thanks guys |
"last one I do in my lifetime"
- how old are you? Buytl tape is cheap & won't add much time - are ya gonna treat your deck like a fine Porsche or a beater 'stang? (either one is just fine BTW) problem with copper is some meth-head tears your deck apart to scrap the copper |
Of course that joist tape is ~40¢/ft |
| All times are GMT -8. The time now is 09:46 PM. |
