It'll be legen-waitforit
stealthn's Avatar
Shouldn’t the world have a choice on this?
https://www.reuters.com/article/us-japan-fukushima-water/japan-will-have-to-dump-radioactive-fukushima-water-into-pacific-minister-says-idUSKCN1VV0CC
Companies are required to have plans for chemical spills and other environmental disasters and cleanup, but shouldn’t this be left to world bodies to decide?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 09-10-2019, 04:05 PM
Unreal. Go figure !
Old 09-10-2019, 08:47 PM
IROC's Avatar
While I question some of the details of why they need to do this, the reality is that "dilution is the solution". There is a lot of water in the oceans. While it sounds like a bad idea, adding this water will have no measurable adverse consequences. It's more of a political problem than a technical problem.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-11-2019, 03:57 AM
Control Group
Tobra's Avatar
I am dubious that it will have no measurable consequences, as it is already measurable.
Old 09-11-2019, 05:09 AM
Almost Banned Once
sc_rufctr's Avatar
Tritium is not a big deal (12.3 years half life) but who knows what else is in the water.
Dumping it in the ocean should not be an option.
So how do you long term store vast amount of radioactive water?
- Peter
Old 09-11-2019, 05:16 AM
Banned
...and Godzilla arose from the depths.....
Old 09-11-2019, 05:52 AM
Platinum Member
dad911's Avatar
NY dumped 80% of it's trash offshore, I believe through the mid 1990's. They didn't consult NJ (where it would wash up on the beaches), let alone the world.
I'm waiting for someone to remember, and figure out how to clean that mess up.
Old 09-11-2019, 06:07 AM
pwd72s's Avatar
Beat me to it...
Old 09-11-2019, 08:40 AM
Almost Banned Once
sc_rufctr's Avatar
Mothra is King
- Peter
Old 09-11-2019, 09:12 AM
craigster59's Avatar
Old 09-11-2019, 09:15 AM
Deschodt's Avatar
I have a friend who was a nuclear physicist, wrote a book on radiation poisoning, and he keeps saying this fukushima is way overblown and there are enough naturally present radioactive material just in the san francisco bay sea water to make several nuclear bombs - if you could gather it easily. I'm not saying dumping that water is good, it instinctively sounds terrible (mostly because it may not dilute quickly and first affect specific regions and fish population via currents and land on our door step), but it may not make an iota of difference to natural ocean radiation levels once diluted overall. Guess it depends how they go about it, all at once, one place, etc... This topic could use input from an independent scientist that's neither working for Japanese power nor greenpeace. Maybe we got one here ?
IROC's Avatar
Doing the math...there is about 2.97x10^21 lbs of water in the oceans. Fukushima claims to have about 1.1 million tons of water stored (2.2x10^9 lbs). That amount of water - while it sounds like a big number - is only .000000000000007407% of the amount of water in the oceans...
Even if it was highly contaminated, that percentage is so astoundingly low that you'd never see it. We can talk discharge rates, mixing ratios, etc. all day long but the reality is this idea isn't nearly as bad as it sounds.
I wouldn't worry about it.
You're not dubious - you're just bad at math.
Mike
1976 Euro 911
Old 09-11-2019, 09:58 AM
Control Group
Tobra's Avatar
I did not do any math at all.
It is already measurable on the west coast of the USA. They have been discharging radioactive water since the day it happened.
The Cesium and Strontium are more of an issue than Tritium.
Old 09-11-2019, 10:38 AM
A Man of Wealth and Taste
tabs's Avatar
Ohhh good then you can eat the seafood and drink the desalinated water that comes from where they dump the stuff..CA would make you put a label on it saying "Known to cause cancer."
Copyright
"Some Observer"
Old 09-11-2019, 10:42 AM
Information Junky
island911's Avatar
Clearly Japan needs to build rockets and blast it in to space.
Seriously, just what alternative exists?
I'm with Mike on this one.
Old 09-11-2019, 10:55 AM
Control Group
Tobra's Avatar
When the concentration achieves equilibrium, the dilution factor described applies. It will be more concentrated in the Pacific until that happens.
What could possibly go wrong in the meantime
Old 09-11-2019, 10:59 AM
No, all of the contaminated sea food is being shipped to LV for all of the free loaders to eat at the various buffets.
Old 09-11-2019, 11:03 AM
Duh! You just need a long hose and one of these
Old 09-11-2019, 11:05 AM
Information Junky
island911's Avatar
The article doesn't say, but I expect that the water that they intend to dump has had as much radioactive materials removed as humanly possible.
Here's an interesting read.
https://phys.org/news/2016-07-pacific-ocean-fukushima.html
...after analysing data from 20 studies of radioactivity associated with the plant, it found radiation levels in the Pacific were rapidly returning to normal after being tens of millions of times higher than usual following the disaster.
Old 09-11-2019, 11:07 AM
Old 09-11-2019, 11:20 AM
