Retired, finally
SiberianDVM's Avatar
Need 160mm x 2mm x 20mm arbor cutting wheel
I need a new metal cutting wheel for my small chopsaw that I bought on eBay? years ago. The box says 160mm x 2mm x 20mm and I can't find any 5-6" metal cutting wheels with a 20mm arbor.
Anybody have a source?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 10-04-2019, 01:32 PM
Platinum Member
dad911's Avatar
20mm arbor blades on Amazon
Old 10-04-2019, 03:44 PM
McMaster Carr is usually a pretty good source for oddball things.
Old 10-04-2019, 03:48 PM
Retired, finally
Originally Posted by dad911 View Post
Those are all toothed and/or too big or too small.
Old 10-05-2019, 05:30 AM
Retired, finally
They only have 12" and 14" with 20mm arbor.
Old 10-05-2019, 05:31 AM
They have carbide blades in the sizes you’re looking for. I assume then that you’re looking for an abrasive blade and not a steel blade?
Old 10-05-2019, 05:41 AM
Retired, finally
Yes, I have a toothed blade for cutting wood, but I broke the OE abrasive cutting wheel that I used for cutting steel and graphite golf shafts.
Old 10-05-2019, 09:09 AM
Well, the carbide blades will cut steel and graphite. You might look at those, if you aren’t cutting a whole bunch of things at a time. Just make sure you look at the rated speeds for the blades and compare that to your saw speed.
Old 10-05-2019, 10:01 AM
Retired, finally
Thanks, if I can't find an abrasive wheel, I'll try a carbide blade. I worry about the graphite getting micro splinters, though, and then the shaft will break.
Old 10-05-2019, 12:12 PM
Well, maybe cut the graphite shafts with a cutting wheel on a Dremel tool.
Can you not get blades from whoever made the chopsaw?
Old 10-05-2019, 12:28 PM
908/930's Avatar
You should be able to use a 6" x 7/8" ID wheel with a 20mm to 7/8" bushing. Did you other cut off disk have a bushing in it?
Old 10-05-2019, 01:25 PM
Retired, finally
It's a knock off "brand" I bought on ebay years ago. No name on original wheel either.
Old 10-06-2019, 07:58 AM
Retired, finally
Original wheel did not have a bushing. Problem is I cannot find a 7/8" to 20mm bushing, either. Would a 22mm to 20mm bushing be close enough or dangerous?
Old 10-06-2019, 08:05 AM
Well, it sounds like this saw is more trouble than it’s worth. Maybe you should get another saw. The other alternative is to make your own bushing, any machine shop could whip one out in about five minutes.
Old 10-06-2019, 08:09 AM
Retired, finally
Well, it sounds like this side is more trouble than it’s worth. Maybe you should get another saw. The other alternative is to make your own bushing, any machine shop could whip one out in about five minutes.
I think this about a lot of projects these days.
I'm gonna try the 22mm bushing with a 7/8" arbor wheel.
Old 10-06-2019, 08:20 AM
908/930's Avatar
The 22mm should be ok that is only .009" under size.
Old 10-06-2019, 11:23 AM
Retired, finally
Ordered disc and bushing from Amazon. I'll let y'all know how it works out.
Old 10-06-2019, 03:52 PM
Retired, finally
Took a while to get the disc, but I got it today and with the bushing it fits perfectly.
Metal cutting disc $5.60 including shipping
Bushing $5.75 including shipping
48 carbide tooth woodcutting blade $15.75
Old 10-22-2019, 01:36 PM
