race fuel and CR vs compression psi
i have a late model stock car with a chevy 350 in it. it has 64cc heads and I run 40degrees advance. and have read the 64cc heads make 10.4 to 10.7 CR.
I did a compression test and it was about 210psi. do I need to run race fuel in it. its an old car and I am thinking about turning it into a track car but don't want to spend $400 in gas for a weekend. |
I wouldn't think mid 10s would be something that would require super high octane race fuel, but you'd probably have a problem running 87octane too. Some others with more experience will doubtless chime in. |
For instance, these will approx yield the following CR with the given specs https://www.jegs.com/i/SRP/867/140674/10002/-1 SRP Small Block Chevy High Compression Forged Pistons Small Block Chevy (+.030") Bore: 4.030" Stroke: 3.480 (355ci) Rod Length: 5.700" 58cc 14.0:1 64cc 12.7:1 70cc 11.7:1 But these are very different https://www.jegs.com/i/SRP/867/138081/10002/-1 SRP Small Block Chevy Flat Top Forged Pistons Small Block Chevy (+.030") Bore: 4.030" Stroke: 3.480 (355ci) Rod Length: 5.700" 58cc: 11.1 to 1 64cc: 10.3 to 1 70cc: 9.6 to 1 76cc: 9.0 to 1 |
yes, was thinking a bigger combustion chamber (70cc) to reduce CR if needed, that way I wouldn't have to change pistons.
I don't know what pistons are in it, assuming flat top pistons,. since I wouldn't have any rules to follow I was thinking of the vortec head but it is 64cc head also. right now it has some old turbo heads on it. I could also pull off the restrictor plate and run a 4 barrel. still in planning stages for the conversion. trying to put everything together that would have to be done. I can still run the car at the circle track here but don't know if that is what I want to do. if I wreck it I don't really have the tools to fix it as far as body and frame. I think it would be a fun track car, also wouldn't worry about it on a road course that much. big question right now is cutting out the chassis to put in a passengers seat, routing the exhaust to lower the floor pan and making leg room for passenger. kinda sucks, just did a week end at NCM and I didn't need an instructor but that track is 11 hours away. wouldn't need to put in passengers seat. |
any way I can figure out what the CR is with engine together.
even at 12.7 and going to a 70cc head only brings it down to 11.7, that would still be race gas. the car was built back in the 80's. don't know if it had a rebuild or when what was done to it. I really doubt it had the hi comp pistons as I don't think the rules allowed those. I suppose I could bore scope it and see whats in it. if flat top then I am looking 10.3CR |
my father in law built the car and wrote the rule book for the track he works at.
his rules say flat top pistons and no more than 10.5cr, I cant imagine any other tracks allowing higher CR. cant really ask him about it. he is strange/sentimental about the car so he does not mention it. I did ask when I got the car from him, did not get much out of him, he mumbles and im deaf. I did ask him about gas and he kind of mumbled and said something like yes, to be on the safe side. so 10.5CR on 93 pump gas ok? |
I found a link that talks about using a manometer.
https://www.autoblog.com/2016/02/23/how-to-determine-compression-ratio/ But it doesn't say what "15" is, I would assume inches of water. Quote:
Do you run mufflers on it? If so you should hear if the engine is pinging on hard acceleration if the octane is not enough. Also 210psi is fairly stout cranking compression - MO / experience is you're a little tall with that amount of advance. You should back that off to 38 total and then see the result. With 40 degrees in you're very likely loosing power in the upper range.
40 to 38, yes
was thinking that too. just read an article in hot rod, the guy said 200psi is his limit for 93 octane. I will have to look at my numbers again, don't remember if it was 200 or 210. |
^^Yes in a conventional iron headed small block - that's about it^^^
OK, right, it doesn't have to be bigger to have more overlap. Also, I think overlap will drop some of the low end power. |
I would say keep the compression and run 93. Slowing down the timing to 36 or 38 is way better than buying race gas. Do the rules dictate the heads and cam? As stated by someone above a cam with overlap will kill cylinder pressure and thats what it is about. Static compression can be high but the right combination of heads and cam can change the cylinder pressure big time.
You can get thicker head gaskets. Felpro says their .05” gasket will reduce CR by half a point. They apparently publish gasket volumes for their various gaskets too, so you can calculate how much a given gasket thickness will change the combustion chamber volume.
I’ll listen to Felpro, I’m pretty sure they know more about it than you do. |
0.05 = 0.050 = 0.050000 (discounting significant digits, otherwise, mathematically, they are the same number)
Just like 1 = 1.0 = 1.00 .1 - tenths .01 - hundredths .001 - thousandths 0.005 = 5 thousandths 0.050 = 50 thousandths or 5 hundredths = 0.05 0.055 = 55 thousandths |
| All times are GMT -8. The time now is 04:43 AM. |
