-   -   replacing water heater (http://forums.pelicanparts.com/off-topic-discussions/1053493-replacing-water-heater.html)
look 171 02-24-2020 08:00 PM
Originally Posted by fintstone (Post 10763307)
Soapy water? You guys don't use a lighter or match to test for leaks?
Now that's a guy who been around a few old timers. I used to do that. AS they say, for reals. My guys have the fancy green liquid for that but I still light a match and take my torch to it. They used to freak out when I do that
silverc4s 02-25-2020 07:03 AM
When I lived in San Jose years ago, we used an off duty fireman to install a new water heater. Overall good Plan I think. Especially of yours is below ground? Ours was in garage.
Lots of earthquake / fire safety considerations.
jyl 02-25-2020 07:21 AM
Originally Posted by AZ_porschekid (Post 10763064)
If your gas line doesn't have a turn off valve at the water heater. You'll have to turn it off at the meter. Gas co will turn it back on when you're ready and make sure you don't have leaks.
The soap water is standard and is in the directions. I'm not sure on the plastic vent, I always go with metal
Luckily there is a valve right by the heater
look 171 02-25-2020 08:52 AM
there should be, code requirement
Zeke 02-25-2020 09:42 AM
A match won't catch a very small leak. You need the soapy stuff and some patience. I connect welding hoses all the time and the soap plus watching the gauges over a period of time tells me whether I'm good or not.
Not to mention that the potential for danger is always present. Yeah, old timers did some crazy siht and I'm an old timer.
When I was really little we had an old plumber that was going to do some work on an old WH that didn't have a temp and pressure release valve. It burst nearly driving him through a wall. It was boiling and making steam. He lived but he was a mess.
We've come a long way since then safety wise.
jyl 02-25-2020 10:51 PM
Success, I think. New water and gas flex lines. Home Depot doesn’t carry pipe dope anymore so I used the thicker yellow “teflon” tape designated for gas fittings. Modified the 2” PVC vent, it takes a straighter path now. Filled, no gas leak per nose and soapy water, blower started, burner ignited, status light is making the appropriate blink pattern, and now waiting for hot water. Took about three hours. Restrapping to the wall was actually the fiddliest part.
I set to 130F because everyone complained about the 140F I used before.
Although this is supposed to be the direct replacement, AO Smith swapped the hot and cold inlets. No idea why. Bored engineer? Noticed it on the pre-flight check.
Thanks everyone. That’s $000s the ripoff Water Heater companies didn’t get!
plumb4u2 02-26-2020 06:44 AM
AO Smith has never “swapped” hot and cold feeds to the heater??? I install AO Smith daily and have been for 23yrs. Care to share a pic of the top of heater?
plumb4u2 02-26-2020 06:46 AM
It’s always hot left cold right this is an industry standard across all brands
rfuerst911sc 02-26-2020 07:05 AM
Maybe the water heater had to be rotated to position the pipe connections correctly ?
dad911 02-26-2020 12:24 PM
Originally Posted by jyl (Post 10764506)
...... Home Depot doesn’t carry pipe dope anymore......
California thing? Must only cause cancer in CA as it's available here.
onewhippedpuppy 02-27-2020 04:43 AM
Just a warning if you used the stainless braided flex lines for your water connections, the internal rubber lining will eventually break down and you’ll get little black rubber particles in your hot water. Took me a while to figure it out, I went back with hard copper tubing.
jyl 02-27-2020 05:27 AM
Yeah - my bad, combination of water heater orientation, late night, and general stupidity.
jyl 02-27-2020 05:33 AM
There was a “kit” at Home Depot, corrugated stainless steel tubing, one blue and one red. There was also corrugated copper tubing for water heaters, like what I had before. I got the kit because the colors were pretty ...
