rfuerst911sc's Avatar
vinyl siding - need cleaning suggestions
Our home has white vinyl siding and it is dirty looking with some mildew in areas . I have a gas powered pressure washer but would prefer not to use it . My fear is the siding installed in 1996 may be brittle and easy to puncture/break with the pressure washer but I know I can control this by distance from wand to siding . Anyway my main question is what chemicals are you guys using ? I'd like to find something decent available at Home Depot as we are a small rural town and HD and a few lumber yards is it for purchasing in person .
In a perfect world the magic juice could be applied with a hand pump up garden sprayer , set for 15 minutes and then rinse . On the back side of the house is the elevated deck that I recently ( past 4 months ) have installed new pressure treated deck boards . So whatever cleaner I use I don't want to damage the boards as I am soon going to be applying stain to the boards . So bottom line for those that DIY clean your siding what are you using and what are your methods .
Old 04-24-2020, 09:16 AM
Counterclockwise?
I found spraying cleaner on was time consuming and expensive.
I didn't notice a difference with or without.
If your pressure washer breaks your siding so will a good wind storm.
Rod
1986 Carrera
2001 996TT
Old 04-24-2020, 09:21 AM
Free minder
Aurel's Avatar
Power washer, with diluted bleach in it.
We hired a guy who did the whole house for $350. Well worth it.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 04-24-2020, 09:46 AM
Don't use a PW. Pump sprayer with 50% bleach....spray from the bottom up to avoid runs/streaks.
Don't leave bleach in the sprayer and flush with fresh H2O afterwards.
PW's can get H2O behind the siding....if you go that route...beware.
Old 04-24-2020, 10:07 AM
Registered ConfUser
Just hired a guy to do ours. Doing what’s called a soft wash, perhaps as what’s described above. We have it done every couple of years without issue, but definitely not with high pressure spraying.
Mike
Old 04-24-2020, 10:29 AM
Model Citizen
herr_oberst's Avatar
Long-handle brush. Bucket.
Old 04-24-2020, 10:31 AM
No need to brush imo....50/50 bleach does it all. A "real" pro will use the same...btdt years ago...once.
Quick & easy....
Old 04-24-2020, 10:58 AM
Member
Great topic in this time of 'honey-do' projects!
My house and deck need regular cleaning due to extensive tree coverage.
Over the years i have experimented with a number of different products and mixes.
Best solution has been a 50-50 mix of Clorox Outdoor and water. It's formulated for siding, decks, furniture etc.
I apply with a bug sprayer, let sit for 5-10 minutes then rinse with the power washer.
I can literally watch the dirt, algae, mold and even light moss just run off down the siding.
Pressure wash only as a rinse, no up close blasting required.
Bleach, even a low concentration, has done bad things to the grass and plantings.
Other products and mixes are OK but the Clorox Outdoor has been BY FAR the best.
It works great on my composite decking and even the concrete pads by the garage and steps.
Enjoy and easy project with immediate visible results!
--p
Paul
91 964 C2 Targa sold (shipped back to the fatherland)
09 Cayman PDK 17 Titan
55 Sunbeam S7 Deluxe
70 Triumph Bonneville
Old 04-24-2020, 11:44 AM
biosurfer1's Avatar
I would think a wide angle pressure washer tip would be more than fine. If that does damage, how's the siding supposed to stand up to a decent downpour?
Old 04-24-2020, 11:47 AM
Rain comes down...spraying up can get behind the siding from the bottom. I had one rental with it...
Old 04-24-2020, 11:54 AM
wdfifteen's Avatar
Spray and Walk away sounds like what you are looking for. I use it on vinyl fence that gets no sun, green and black molds grow on it.
Spray this on and leave it. In a month our so the mold is gone. It does take patience, no immediate gratification, but it does work and the mold doesn't come back for years.
https://www.homedepot.com/p/30-Seconds-1-Gal-Cleaner-Spray-and-Walk-Away-100506799/202897313
Old 04-24-2020, 12:02 PM
Oh btw...bleach is bleach...regardless of the label or brand. Laundry, Cleaning, Outdoor....methinks they're all 6% Sodium Hypoclorate in the jug...nothing more, nothing less.
So with 50/50 you're actually using a 3% bleach solution.
Old 04-24-2020, 01:04 PM
The pool stuff is 12%.
Brent
Old 04-24-2020, 01:13 PM
I stand corrected....I've just used the super market & outdoor stuff.
Old 04-24-2020, 01:17 PM
No worries, it isn't the regular cleaning stuff.
Brent
Old 04-24-2020, 01:21 PM
This stuff works pretty good. I use it in conjunction with bleach.
Old 04-24-2020, 02:37 PM
Old 04-24-2020, 02:41 PM
