-   -   Siding question (http://forums.pelicanparts.com/off-topic-discussions/1064952-siding-question.html)
porsche tech 06-21-2020 09:23 AM
Siding question
I am replacing various pieces of the ship lap Cyprus siding on my house. Some pieces of it have started to have some rot at the very bottom edge. A friend suggested putting some caulk across the bottom edge of each board to keep it from wicking up the board. I was thinking that might keep water in. I even thought of putting Flex Seal on the bottom of each board. Any thoughts? Is it worth the effort. The siding is original from 1979 so the new boards will outlive me as is.
http://forums.pelicanparts.com/uploa...1592756524.jpg
RWebb 06-21-2020 10:54 AM
Agree
also clear that crap away from the house; put pavers there maybe
prime & paint the first 6" of the edges and back side of the boards
I do that stuff during the dry season in our rain forest here
cabmandone 06-21-2020 11:01 AM
Good point about getting stuff away from the home. Make sure water doesn't run back towards the house as well. If there's nothing there to hold moisture for the boards to wick you'll reduce the likelihood of having to replace the boards due to rot.
look 171 06-21-2020 12:53 PM
Get that clear up near the bottom will help A LOT. Another way is if you decided to reinstall new boards, but a slight angle, 7-10drgrees, toward the outside so the water doesn't wick back toward the house. Its a PITA for every board but its cheap insurance.
RWebb 06-21-2020 01:03 PM
can he just stick wedges down at the bottom for the uninstalled boards?
look 171 06-21-2020 01:28 PM
Wedges? No, you want those boards off the ground or soil. Keeping a piece of wet or damp is what cause rot. Its needs to dry.
A930Rocket 06-21-2020 02:16 PM
Code now requires 6” clearance. Can you install a French drain around the house as needed to keep water away. Of course, being in the low country, you might have trouble running it to a low area.
Is that chain coming off your gutter? You might need to install a drain off the gutter and pipe it away from the house.
RWebb 06-21-2020 03:17 PM
No I mean a wedge under the board in between it and the house sheathing to get that angle you mentioned.
gduke2010 06-21-2020 03:54 PM
Termites are also, a problem with wood so close to ground.
porsche tech 06-21-2020 04:11 PM
Thanks for all the input. As I said, the original siding was put on in 1979 so they've lasted over 40 years. I like the idea of painting the back lower portion before install but I'm not going to try to seal the bottom edges. I try to keep the leaves and pine straw away from the house but there's so many trees around here it's a tough job.
RWebb 06-21-2020 04:33 PM
trim them trees
esp. if they are near the house
fire danger is not just for the western US...
look 171 06-21-2020 05:40 PM
No, not angle like that. The angle is cut at the ends of the board to create http://forums.pelicanparts.com/uploa...1592786417.jpg
look 171 06-21-2020 05:42 PM
Sorry. Forgot to show in drawing. the slight angle is cut at the bottom of the siding yo keep water working back up into the ends of boards
RWebb 06-21-2020 06:25 PM
aha! just like a Kamm tail
LWJ 06-21-2020 08:42 PM
To Look's point. Tonight at a BBQ for Father's Day, we discussed a plank that has been exposed to weather for 55 years with no treatment. It is fine. Why? Because the water drains off it.
look 171 06-21-2020 09:08 PM
Lots of younger guys (illegals, in our case, or legals folks from south of the border don't read or follow simple instructions) that come into the trades don't know, don't ask and don't care anymore. They make money doing simple tasks and have no idea about anything more complex then the installation of a simple store bought item. The old, "Just nail it up, it will be fine" BS.
look 171 06-21-2020 09:17 PM
I jjust noticed that drip chain. Is that what it is? Get rid of that. Its in a really bad location. You are inviting water to drip and collect at the very corner.
porsche tech 06-22-2020 03:10 AM
The drip chains are very common around here because most houses have a very wide overhang at the eaves and a downspout would have to turn back to the house at a pretty severe angle. The chain goes into a hole that is filled with rocks. Maybe I could aim it into a splash pad that's pointed away from the house. I like the idea of making the bottom cut at a slight angle.
