-   -   Rehabbing my workshop. Need advice (http://forums.pelicanparts.com/off-topic-discussions/1067961-rehabbing-my-workshop-need-advice.html)
BK911 07-26-2020 06:11 PM
Looks like a lot of work!
But should be worth it when done.
If you properly size the AC unit you won't need a dehumidifier.
Biggest mistake with a dx unit is over sizing it.
Error on the smaller side so it runs more and wrings the moisture from the air.
mepstein 07-26-2020 06:24 PM
The building is 20x24 and will be insulated at the attic rafters so the 2nd floor will be conditioned. I was planning on using a 12,000 btu, 22.5 SEER. Too big? Would the 9000 btu sized one be better?
dad911 07-26-2020 06:28 PM
Originally Posted by mepstein (Post 10962387)
Started on the tear down. Every stud bay is contaminated with mouse crap. Even had one scurry out as I was pulling off the paneling. I will be ditching the fiberglass in favor of rock wool. Once I pull all the insulation out and remove the exterior siding, I’ll bleach and power wash the studs and base plate. Then probably brush on a coat of Kills primer. ......
Skip the kilz. Use this stuff, seriously.
Originally Posted by dad911 (Post 10955624)
After you pull out the insulation, spray any evidence of mice/rodents with this stuff: Back-a-zap
BK911 07-26-2020 06:32 PM
Rule of thumb is about 600 sq ft per ton.
Are you putting soffit venting in?
And spacers behind the insulation?
And a ridge vent?
mepstein 07-26-2020 07:02 PM
Rule of thumb is about 600 sq ft per ton. Good to know.
Are you putting soffit venting in? Yes, already there
And spacers behind the insulation? Yes. I did that in my house attic reno. I know it's important.
And a ridge vent? Yes, already there.
mepstein 07-26-2020 07:03 PM
Will do. Thanks
Edit - Just ordered. Thanks
RWebb 07-26-2020 10:12 PM
use bleach first - rodents and their scat can carry many diseases
and wear a good mask when working until then
mepstein 07-27-2020 03:05 AM
Always. :-)
Selfie pic
I have a garden sprayer that I’ll use to wet it all down with bleach and then use the odor eliminator once I vacuum up all the debris.
http://forums.pelicanparts.com/uploa...1595844320.jpg
