Unconventional bolt - please help identify
These oddly shaped flat flange headed bolts hold the big mirrors onto the side of this 65 International I am sprucing up. Any idea what they are called so I can source a handful? I am missing a couple and need eight. Acorn nuts should be easy to find.
http://forums.pelicanparts.com/uploa...1596136822.jpg http://forums.pelicanparts.com/uploa...1596136839.jpg |
Those look like resistance weld studs to me, they should maybe have be projection welded into the door about 100 years ago....
T-bolts
Yup, what he said ^
Tee Bolt 1/4"-20, 20 PK (more choice) - POWERTEC |
This style of bolt slides into longhood aluminum bumper trim and then through the front and rear bumpers.
You could probably use an elevator bolt if you can't find the exact replacement.
Yep. All good, my friends. Thank you. This should be easy.
Thanks for the link, Aerkuld. |
If you have a local Fastenal they probably have them
Nice! |
More pictures of the International. I have a 63 in my side yard now. Grandpa bought it new. 30K original miles. Looked good until the barn fell on it.
Sort of like the stud version of a captured nut
http://forums.pelicanparts.com/uploa...1596143326.jpg http://forums.pelicanparts.com/uploa...1596143349.jpg After five months in shop (among other projects). http://forums.pelicanparts.com/uploa...1596143441.jpg 22 holes in roof plugged with weld (professional welder, and I held the brass rod inside the cab) and many peeps (across time) on hands and knees installing and repairing sirens/lights. http://forums.pelicanparts.com/uploa...1596144403.jpg Filler primer after epoxy. http://forums.pelicanparts.com/uploa...1596144517.jpg Washing etching acid out of interior. http://forums.pelicanparts.com/uploa...1596144560.jpg http://forums.pelicanparts.com/uploa...1596144611.jpg Before any wet sanding http://forums.pelicanparts.com/uploa...1596144642.jpg Some sanding and polish http://forums.pelicanparts.com/uploa...1596144673.jpg http://forums.pelicanparts.com/uploa...1596144708.jpg |
Front thingie back from powder coater.
http://forums.pelicanparts.com/uploa...1596145114.jpg Inventory tag in door jamb. Spots are polishing compound. http://forums.pelicanparts.com/uploa...1596145136.jpg |
Sweet!
Thanks! |
Bob, that's a great truck, is that yours or for a customer ?
We should have an IH thread around here, i might have to start one... |
Quick story. I broke the passenger door window when gutting the door. I freaked out. Found an IH salvage place in Washington state. "Is there any way to get another window?" Guy says "Relax, I have 50 of them in the yard". They are all the same regardless of model across many years. Phew. $80 - Sold! |
looks identical to the bolts that came with a toilet wax ring I just installed. You could probably find these bolts at a hardware plumbing section
http://forums.pelicanparts.com/uploa...1596219699.jpg |
Trailex also uses them to hold most of their aluminum trailers together. Drill a hole in your anvil and hammer a hex bolt head flat then file/grind to fit.
Also https://www.rockler.com/t-slot-bolts-pack-of-five-1-4-20-thread?country=US&sid=V91040&promo=shopping&utm_so urce=google&utm_medium=cpc&utm_term=&utm_content=p la&utm_campaign=PL&tid=pla&gclid=Cj0KCQjwgo_5BRDuA RIsADDEntSo-BjBVN3dzt6yPHelx48C3sl6QhHk6XwnOfodQRPO-QIYilrM05EaAks_EALw_wcB |
However, the only stainless acorn nuts were 1/4-20 at Lowes, so brass toilet bolts for the win. http://forums.pelicanparts.com/uploa...1599066886.jpg http://forums.pelicanparts.com/uploa...1599066909.jpg http://forums.pelicanparts.com/uploa...1599066940.jpg |
I love me some home depot engineering.
Dad's old '64 Travelall had mirrors a lot like that on it.
Had three gas tanks @60 gals total, split rims, it was a 1200 series. They don't make them like that any more. |
Beat me to it, by a month - toilet bolts is what I thought as well. http://forums.pelicanparts.com/uploa...1599094527.jpg
Those non-wax rings are great. Reusable and a more secure seal. The void in the base of the toilet makes a good hidey hole. These rings make it simpler to use it. |
T bolt or Trim bolt.
| All times are GMT -8. The time now is 03:21 AM. |
