FUSHIGI
Shipping a used scissors car lift from a residence
Looking at buying a lift from a private party in suburban NJ but they are unable to put it on a pallet for pick up.
Any ideas?
Cults require delusions.
Old 08-13-2020, 12:43 PM
UnRegistered User
billybek's Avatar
How far are you from the seller?
I met a tilt bed tow truck to move mine when I had purchased it used.
Quick and easy and safe.
Edit: Mine was a scissor lift so might not be applicable to your situation.
Edit again! Just re-read the title...
Bill K.
Old 08-13-2020, 12:49 PM
FUSHIGI
I'm a little less than 900 miles away. : (
...but do like the idea of a tilt bed with a winch!
Old 08-13-2020, 01:20 PM
I'd try your local moving companies. If they can't make the drive, then maybe they can take the palletized and strapped cargo to a trucking company. Someone's got to have a backhaul that they can put the lift on.
Old 08-13-2020, 02:14 PM
Tilt and load is the right answer. But 900 miles isn't practical.
It needs to be put on a skid, and transferred to a common carrier, or you go get it.
Personally, at 900 miles away I wouldn't even consider it.
Old 08-13-2020, 03:14 PM
Whatever you do, don't use one of those "hot shot" guys. He'll wreck it a mile from your home.
Old 08-13-2020, 04:22 PM
Platinum Member
dad911's Avatar
How far from 07924 ?
Old 08-13-2020, 04:47 PM
FUSHIGI
Using zipcodes, Mapquest has it 48 miles.
Old 08-13-2020, 04:57 PM
Mike80911's Avatar
When I bought mine I attached wheels to it using u bolts and dolly wheels. Made it real easy to move around. I rented a tilting trailer pushed it right on and off and into place then removed the wheels. I got the idea from a thread on here but I can't seem to locate it now
89 930 Cab Black
11 Cayenne
Old 08-13-2020, 05:39 PM
FUSHIGI
Another good idea! Thank you!
Old 08-13-2020, 05:48 PM
I bought mine it came with free shipping but I had to put forks on my tractor to go get it from the truck. It was too heavy so I had to split it into two loads to pick it up with my tractor.
Good luck
Tony
Old 08-13-2020, 05:53 PM
FUSHIGI
Good luck
Tony
Thanks! Shipping is definitely a challenge.
Old 08-13-2020, 06:20 PM
Home of the Whopper
Cherry picker will get it in and out of a pick up truck.
Or onto a pallet.
Old 08-14-2020, 03:56 AM
