Banned
RWebb's Avatar
Cleaning Ductless Heat Pump
Daikin mini-split - it's 7 years old and seems to need cleaning all the damn time - manuals says after several seasons, but it's more like every 6 months
I'm not talking about the $150 cleaning (where some kid knocks the dirt off of the plastic filter)
I'm talking about the squirrel cage blower fan which is full of crud and very hard to see, much less get at. It costs $350 for a kid to spray foam in there, then catch the drips in a funnel shaped plastic bag that leads to his 5 gal. pail.
Anybody know how to really clean these?
Old 09-22-2020, 04:26 PM
biosurfer1's Avatar
Compressed air wouldn't work? I'm sure it would create a bit of a mess, but I would think a strategically placed vacuum could catch most of it.
Old 09-22-2020, 04:45 PM
credulous Boomer rube
same problem with the Mitsubishi. It takes the tech longer to take the unit apart than to clean it. So far it has been a once a year cost at $330.
'88 Targa
Old 09-23-2020, 09:56 AM
Banned
RWebb's Avatar
Compressed air would work on the dust - and create a huge mess even with a shop vac
won't work on the 'crud'
Old 09-23-2020, 11:54 AM
peppy's Avatar
Crap I didn't know I needed to to this, and there is no way I'm paying $300 to have it done. Mine is 2 years old and does have mildew on the louvers that I have wiped down with dish soap and bleach water. That seems to take care of it for a few months. I have never taken it apart.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 09-23-2020, 12:22 PM
peppy's Avatar
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-23-2020, 12:38 PM
Banned
RWebb's Avatar
Well, the Daikin manual says you may need to clean it after a "few seasons." Mine won't last that long.
None of the kids* who have come out to clean it have taken it apart either. They shoot some sort of foam or something else in there, then rinse it off - as in the Fujitsu video peppy posted. Maybe that isn't effective?
There must be instructions on cleaning in some manual for HVAC "expurts" that Daikon puts out but I haven't seen it anywhere.
* it seems there is a real shortage of people in this area, like the rest of the trades
Old 09-23-2020, 12:41 PM
peppy's Avatar
Spraying coil cleaner with a garden sprayer and then rinsing with water using the same garden sprayer should do most of it. That is how I clean evaporators in walk in coolers. The mini split should have a drain that can handle the liquid.
I may give this a go this weekend and see how it goes. Mine is in a kitchen so I'm not worried about water on the floor. I will try and drape with plastic.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-23-2020, 01:13 PM
Banned
RWebb's Avatar
I'm pretty sure those ready-made plastic funnels are sold somewhere...
Old 09-23-2020, 01:14 PM
The problem is cleaning the squirrel cage blower fan. It fills up with lint? and greatly reduces the efficiency of the fan, to the point the blower will put out no air flow.
'88 Targa
Old 09-23-2020, 01:19 PM
peppy's Avatar
I found this one from supply house.
https://www.supplyhouse.com/Nu-Calgon-4150-01-Clean-Guard-Mini-Split-Maintenance-Bag
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-25-2020, 09:33 AM
peppy's Avatar
https://www.amazon.com/Split-Conditioning-Service-Mounted-Cleaning/dp/B087639WRK/ref=sr_1_6?crid=W4WSZFQ068ZN&dchild=1&keywords=mini+split+cleaning+kit&qid=1601051660&sprefix=mini+split+c%2Caps%2C232&sr=8-6
This one is cheaper
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 09-25-2020, 09:35 AM
peppy's Avatar
I cleaned ours a few weeks ago using the drape from amazon and a pump up sprayer from harbor freight. I used a coil cleaner and rinsed it with water, then used a mold/mildew tile spray for the plastic parts behind the blower wheel. I did not take the blower wheel out, I just removed the covers. It was pretty dirty, but came clean in about 1.5 hours.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-23-2020, 05:06 PM
canna change law physics
red-beard's Avatar
I will never complain about replacing AC system whole house (4" thick) filters again.
James
Red-beard for President, 2020
Old 11-23-2020, 05:30 PM
peppy's Avatar
If I had known this is what was required I would never have agreed to put one in.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-23-2020, 06:10 PM
dan79brooklyn's Avatar
Yep. I live in Japan. We have 4 split system AC units all Daikin. The big one in the living room stopped blowing cold air this summer. I could see that the fan was covered in dusty grime. We had a technician come out and he confirmed my suspicion that it needed to be cleaned. He was nice enough to show me how to clean it and didnít charge us anything. Basically take off all the plastic covers to expose the long horizontal fan and go in there blade by blade with small brushes/toothbrush. It will take a while and make a mess. Wear a mask and keep a vacuum going underneath you. But 30-40 minutes later youíll be done and itíll blow cold and clean again.
Old 11-23-2020, 10:45 PM
UnRegistered User
billybek's Avatar
Do you leave the fan on continuous operation or does it just cycle on with a call for cooling or heating?
Since you don't have a central system filtering the air, how about a stand alone hepa filter in the house near the head unit? Would at least knock some of the dust out of the air and maybe prolong the run time between cleanings.
Bill K.
Old 11-24-2020, 05:14 AM
red-beard's Avatar
Sounds like a missing feature. They need a filter on the air handler/evaporator
James
Old 11-24-2020, 05:25 AM
UnRegistered User
billybek's Avatar
There is a filter... It is sized to stop small rocks.
Bill K.
Old 11-24-2020, 04:36 PM
Banned
RWebb's Avatar
this is a Daikon, aka "lousey radish" heat pump
the squirrel cage blower collects dust and MOLD
it cannot be removed w/out removing the entire unit from the wall
!@#$%^&*()_(*&^%$#@!#$%^&*
Old 11-24-2020, 04:42 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
