-   -   Power outage protocols (http://forums.pelicanparts.com/off-topic-discussions/1076170-power-outage-protocols.html)
Scott Douglas 10-20-2020 07:26 AM
We're having an outage for maintenance this morning. 4 hrs, 8-12.
I've already got one car out of the garage as the door opener is not easily gotten to with both in the garage.
I'm thinking since they say they'll be turning the power on/off several times during this 4 hour period that it might be prudent to unplug the surge protestors on all our computers and sewing machines, rather than just turning them off.
What is the consensus?
Thanks.
Esel Mann 10-20-2020 07:34 AM
unplugging things certainly won't hurt. an easier solution may be to turn off breakers. plus if you are concerned about surging there typically are other items besides puters n sewing machines that wont be happy with you!
GH85Carrera 10-20-2020 07:48 AM
I am no electrical engineer, but I would think turning off the power strip surge protector is about the same as unplugging it. In a lightning strike unplugging is better, but lightning is kinda hard to predict, so most people just have a surge protector as a their name implies.
For me is a pain in the butt with no electricity to get the cars in or out of the garage. I have to open the door after I pull the handle, and open the door, get in the car, pull the car out, lower the door and lock it, then go through the kitchen and out the back door, around the house down the side yard to the driveway. It makes me really appreciate electricity.
Tobra 10-20-2020 07:48 AM
Turning it off at fuse box would be easiest. I don't know if it would work for a lightning strike, but it couldn't hurt and that was what I saw it used for
1990C4S 10-20-2020 08:33 AM
I am. And I would do nothing.
stevej37 10-20-2020 08:50 AM
I don't remember ever being warned about an outage. They just do it around here.
wdfifteen 10-20-2020 09:26 AM
Around here I unplug electronics and things (refrigerators and air conditioners) that are all going to try to start up at the same time. The power seldom comes on smoothly - on/off on/off and couple of times before it's on for good. It may be perfectly fine for 3 freezer compressors and two AC units to try to start up at the same time, but it's easy enough to hit the breakers.
3rd_gear_Ted 10-20-2020 09:49 AM
Since only electricians and God can make light.
Here's my $.02 worth.
I've seen the voltage get changed when the utility changed the transformer taps. Voltage would get too high in the evening. I reminded the utility via e-mail to keep my max voltage within U.L. parameters or my insurance can be compromised.
Just a CYA thing I did cuz I could as a smart a** Electrician.
GH85Carrera 10-20-2020 11:23 AM
Anyone with a match can make light.
Scott Douglas 10-20-2020 11:40 AM
Thanks everyone. We came thru the outage without incident. I was even able to get my wife's iPad up on the internet after I turned off our router early.
'YOU DIDN'T TELL ME THAT WAS GOING TO HAPPEN!'
Good thing I'd gotten instructions on how to do that from my good buddie Zeke back in KC Mo last night. I'm a newbie when it comes to iPhones and all this iPad stuff.
GH85Carrera 10-20-2020 01:22 PM
I don't know what router you have, but it should handle a restart from off and go back to operation with no input from you at all. And so should the iPad.
I update the firmware on mine, and do a restart and it just stops the internet during the restart, but comes right back.
Scott Douglas 10-20-2020 02:13 PM
They did Glen. The problem was when I turned it off early. She wasn't aware that when the power was going to be off she wouldn't have internet access. I was able to use her phone as a hot spot and she had access during the whole outage time.
GH85Carrera 10-20-2020 02:21 PM
Ok, now I understand.
I would hear about killing the internet for my wife's iPad as well.
rwest 10-20-2020 02:25 PM
We seem to be getting more power outages around here, so I bought a UPS and plugged my WiFi router and cordless phone into it so I would still be able to use phone and internet to see if the outage was reported, find out expected restart and after that still have something to do or watch on the laptop and iPad.
Just need a battery backed up sump pump to keep from overflowing the sump.
I heard about internal battery backed up LED tubes that retrofit into 4 ft fluorescent fixtures. Going to see if it’s true in a week or so and may buy a couple and put in strategic locations- they should run for 90 minutes- of course if I’m not home, they’ll just light up place for the spiders.
Por_sha911 10-20-2020 05:47 PM
I was under the impression that compressors don't like off/on/off/on restarts. I make sure the Heat Pump isn't getting cycled 5 times in a minute.
Alan A 10-20-2020 06:51 PM
Last outage blew the invertor in the kitchen fridge.
Cost $900 for a $350 part.
Next one will be $350 since he didn’t attach the ground wire and I ended up climbing up there to look anyway.
My point being that’s the only thing in 12 years of regular outages that ever blew because of power fluctuations. If you have an expensive fridge and no supplemental power, consider flipping that breaker.
MAS956 10-20-2020 08:40 PM
I recently invested in a whole house surge protector. I hope those things work - thanks, PG&E.
KFC911 10-21-2020 04:32 AM
I just wait for the power to come back on. 100% sucess rate... no issues.
Quit making up "problems" :D....
1990C4S 10-21-2020 05:46 AM
That statement is correct, but typically they just draw too much current and the CB trips.
Your thermostat is supposed to prevent short cycling, assuming it's 'modern'.
widebody911 10-21-2020 05:53 AM
I've had enough equipment fried over the years to know better.
