Powered roof vent?
7 am every morning. Are you sure it's not an alarm clock? Possibly one if those Teasmade types?
This is the reason I run a pedestal fan at night, it eliminates me from hearing the creaks/groans of an old house, it also helps with traffic noise, and makes me sleep sounder.
subscribed for the outcome.
Also, You can download a spectrum analyzer app on your phone and use that to try to find the source of a noise if you are able to wander around when the noise is occurring. |
That caulk gun is a structural component, better put it back.
Where does the main enter your house? Between yours and neighbors house? Not sure if code would allow one main feed and split-off between the homes. |
Someone running a sprinkler system nearby?
We get some quiet knocking noises in our basement sometimes when the city buses drive by on the next street over from us. It's not every time, so i figure it must be a resonance that only happens when they pass at certain speeds. |
Don't you mean when his wife showers? A close analysis might be in order.:D |
Speculate all you want.
He hasn't responded since last night. Call in the pro. http://forums.pelicanparts.com/uploa...1607468189.jpg |
I may have figured out the noise but I could not explain the timing... You could be onto it ! |
Based on the location near the foundation wall with the adjacent the hillside, I'm going with rodent.
The sound and timing make me think a Rattus Norvegicus is attempting a home invasion every morning. |
Got a good recording of it today... It's lighter jackhammering now - again 7 to 7:20 AM. Weird. I went outside in my PJs and I can hear that noise putting my ear near the main water pipe entering the house. Water for sure. I see no leaks in the crawlspace, so it's just a vibration. I cut off the main, noise stopped. Then again it does come and go for those 20 minutes.
I also cut off the fridge water supply - will see what happens tomorrow.Capture below, need sound on high...definitely not animal as I hear it. https://u.pcloud.link/publink/show?code=XZBf84XZYhArWiW6tDRMDlhaupAnDVDxdbaX |
sounds like something with a bearing that is on the way out
Have you seen the movie The Gate?
I agree. first thought was "sounds like a bearing starting to go out".
Maybe something fluid as well? Edit, didnt see water main part of post. Got something on a timer? fridge ice maker? water heater? sprinklers? |
I'm sticking with 'water softener' until the OP is sure that he doesn't have one.
the cat stares at one corner in the spare bedroom ceiling for hours on end. we call that spot the hell portal.
| All times are GMT -8. The time now is 09:11 AM. |
