Brew Master
Looks like you've got a 3.5 ton heat pump with electric resistance heat. I'd think 50 is a bit high for the balance point. I run mine (1994 Carrier) down into the 30's in NW OH. Some of the older systems had outdoor temperature sensors, set at the balance point, that would automatically switch the system to stage 2 emergency heat once the outdoor temp hit the balance point.
You hit Eheat with electric backup, you want to make sure your house is firmly attached to the earth because you're electric meter will be spinning like a helo prop. ![]() In case you don't know, Balance point: The point at which the extractable heat energy gets too low for a heat pump to adequately heat your home is called the balance point. I used to install heat pumps with electric backup but I'd stage in the electric resistance heat to supplement the heat pump as temps got closer to balance point. What I mean is the heat pump and one bank of electric resistance heat would kick in. This kept the customer from bringing in 10Kw of electric resistance heat all at once like you'll probably be doing. I doubt the electric is staged. And if this is your first heat pump, don't freak out if you look outside and see frost on the coil.... that's normal. As long as the refrigerant lines aren't frosting (that's bad), the coil will frost during operation. The system will have a defrost cycle that triggers by run time, temperature of the coil, or a combination of both.
Nick Last edited by cabmandone; 12-30-2020 at 04:00 AM.. |
You have been given good advice on your existing system , limp it along the best you can until replacement . Last year I had an 18 SEER dual fuel heat pump system installed at our home in the north GA. mountains . It replaced a dual fuel system installed in 1996 . In our case our fuel is propane . Our electric bills since the new install have consistently been $50.00 - $80.00 LESS per month than the old system .
A dual fuel setup gives you the ability to heat/cool with the heat pump ( electric ) and when needed have the LP fired furnace kick in . For us generally the furnace comes on around 35 degrees and colder . I am very happy with the performance of our system . If you end up going the LP route I highly recommend you BUY a tank vs. RENT a tank . When you buy a tank you can shop around for price/specials as any distributor will fill your tank . If you rent the tank the company you rent from is the only one that will fill it . At least that's how it is around here . Adding LP also opens up the possibilities of adding a LP water heater or cook top or any other appliance you may want . I bought a used 500 gallon tank off CL for $200.00 and set it in place myself . It replaced a tank that the previous owner returned ( rented ) when we bought the house . Hookup was easy as everything was already there . Our house has the LP furnace and a cooktop , that's all we currently have running LP . Our tank fill lasts over a year so quite economical . Obviously the more appliances you add the more fuel you will go through . Good luck with your system .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Brew Master
Either way, I think 50 is too warm to change over. I run mine lower than that. Having an older home and being in the flat lands, when it gets cold and windy I'll switch over to Eheat manually rather than allow the thermostat to do it.
Nick |
Brew Master
Nick |
Good to know that in your area, renting a tank locks you into that provider. I'm not a fan of being under a monopoly if I don't have to be, and I can see that being a pretty common monopoly, "our tank, our propane." The house has at some point had some sort of gas. I'm assuming propane. There's one corner of one room that's got a pipe nipple with a valve sticking up out of the floor. I think the room had at one point been a or the master bedroom, so I'm assuming it was for heat.
Cars & Coffee Killer
Did a new hot water heater in March. Thanks to the EPA, they are super expensive now. I did a hot water heater in 2006 and paid $200, installed. This year, it was $2,000, installed. That said, I replaced and electric hot water heater (the previous residents LOVED electric appliances) with a natural gas one. My electric billed has dropped from $200 a month to $100, and my gas bill has doubled from $20 to $40 in non-winter months.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
UnRegistered User
30 years of service from the old Trane unit!
Unlikely that will happen again.... I would do some serious research as to getting the most effective/efficient unit installed. I imagine you run your a/c down there a lot more than you run heat. Saving $50-80 per month on your electric bill will make the bitter pill of first cost much easier to swallow. The cheapest install cost will net you something that Wayne has going on in his HVAC thread. Re-sizing ductwork for airflow and seam sealing all the connections you can see makes a huge difference as does duct insulation where it is accessible to install. Sheet metal is actually pretty inexpensive but the cost to install can be pricey. Beware of the installers that tell you that everything is great and flip in an air handler and condensing unit and give you a tail light warranty. Usually sad install stories begin with these words. "I have found a guy that will do the job for way less than any of the other companies I have quotes from." Walmart pricing? Expect cheap crap. Going dual fuel is a great idea IMO.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Brew Master
Something to consider too, putting a high efficiency system in a low efficiency home doesn't create the anticipated savings. With the home being new to you, I'd consider an energy audit to help you create a plan for overall energy savings before updating the system.
Nick |
It looks like prices aren't insane on the heaters themselves, so I'm assuming it's the installation that you got screwed on. Good to know. I'll probably end up paying someone if we go propane since the existing is electric.
You may be allowed to buy the less "efficient" hot water heaters in Texas. I should have said "IEPA" instead of "EPA" in my post. In Illinois we are required to buy the ultra-efficient versions of everything.
Flat Six
I worked for an electric utility and we did these all the time. For some homes (typically older homes w/lower income homeowners), we were able to refer owners to local programs that helped offset the cost of improved sealing, insulation, windows, etc. Our utility also ran rebates/credits for new heat pump installation and had a list of certified contractors/installers. Of course this was in the uber green, eco-focused PNW. But well worth checking w/your electricity provider.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
![]() ![]() Quote:
Brew Master
Another tip. You can find calculators online for savings based on the SEER rating of your current equipment vs new. You can also run cost savings from a 13 SEER (current minimum) versus the higher SEER rated units.
Nick |
Just wanted to add the system we had installed has a lifetime warranty on the heat exchanger and 10 years on everything else . Other than normal yearly tune ups everything is covered if there is a failure . That warranty pushed me to go with the more complex unit vs a simpler lower SEER unit . My monthly savings on my electric bill will pay for the installed price in 10 years .
Anyone got any idea what SEER a good system would have been if installed in late '91?
Brew Master
I think 10 Seer was the normal back then but not 100% sure. It might even show SEER on that label you posted in your first pics.
Nick |
Brew Master
Well that's weird! I punched the Model number on your pic into the Google machine and couldn't find a manual for it.
Nick |
Yep, I've tried the model # for the indoor and the outdoor portion and got nothing. I can only assume that they are too old to be on the 'Net.
