-   -   We've talked tractors, how about 3-pt hitches? (http://forums.pelicanparts.com/off-topic-discussions/1082249-weve-talked-tractors-how-about-3-pt-hitches.html)
latunabernie 01-03-2021 12:24 PM
Your missing a metal sleeve that goes over the lower pins.
I put them on all my implements.
Tractor Supply or any tractor dealer will have them.
They are cheap.
The center ID. & OD.. are standard.
They do come in different lengths.
In a pinch 1" gal plumbing couplers have worked.
Bernie
dleatherbu 01-03-2021 05:20 PM
Hitch pin diameters
Lower hitch pin diameters and spreads:
CAT I 7/8" ; 15-3/4"
CAT II 1-1/8" ; 32-1/2"
CAT III 1-7/16" ; 38"
Bushings from one category to next readily available in hardened material from most tractor/implement suppliers.
wdfifteen 01-03-2021 05:48 PM
Originally Posted by dad911 (Post 11164951)
I think the difference is cat1 to cat2?
Maybe. A ct2 pin would certainly fit in the hook. Maybe they were looking for a universal size.
rusnak 01-03-2021 05:50 PM
Am I the only one who does not see a need for such a thing? It's not that difficult to switch tractor implements and frankly, something banging around back there would bother me too much.
Crowbob 01-03-2021 06:10 PM
They don't bang if they're hooked up properly and the lift arms are tight.
I opted out, too. The attachments I use are all on dollies which makes hooking them up pretty easy. Plus, my HF was sold out.
wdfifteen 01-04-2021 05:00 AM
It could be a Godsend to me if it works. The rototiller weights 400 lbs. and doesn't slide easily even on concrete. The Kubota doesn't have extendable lower links. Hooking it up is a literal pain in my back, and my back has enough trouble as it is.
wdfifteen 01-04-2021 11:01 AM
Went to TSC this morning. None of the cheap bushings were the right size, but they did have a bushing kit. It's held onto the pin by roll pins that go through the lynchpin holes. It's a great solution except for the price - $34. Someone on eBay is selling the same lift arm kit plus a top link bushing for $4x.xx. I think I'm going to order one for the roto tiller. It's a bear when you hit a rock.
http://forums.pelicanparts.com/uploa...1609790258.jpg
A simple bushing would have created its own problems. The quick hitch obscures part of the lynchpin hole.
The bushing fits in the quick hitch receiver nice and snug.
I'm going to need the top link bushing for the roto tiller. I can put a piece of hose over the pin for the weight bracket and the snow blade.
rusnak 01-04-2021 11:56 AM
Did you say you have concrete? OK, then a suggestion. Can you somehow find a blue CHPP pallet, screw some flooring on one side, and lag bolt some heavy duty castors on the flooring, to make a moving platform for the rototiller? I think that would make it a cinch. 400 lbs is still on the small side for me. I think my box scraper probably weighs around that much.
wdfifteen 01-04-2021 12:44 PM
That's a good idea, and it might work. The place I store it is just inside a sliding door that is about 6" wider than the tiller. Getting to it is a royal pain. If I put it on a rolling pallet I could wheel it out to a more accessible place.
rusnak 01-04-2021 01:07 PM
^ What you need is a farm forklift.
You can use a pallet and pallet jack too.
dad911 01-04-2021 01:16 PM
Sorry WD, looks like my thread sent you down a slippery slope....... SmileWavy
wdfifteen 01-04-2021 03:52 PM
I have pallet forks for the FEL. I can put it on a pallet and move it in and out of the barn. Hooking up would be a lot easier if I didn't have to work in such a constricted space.
wdfifteen 01-04-2021 03:55 PM
Yeah, but I have a feeling my back will thank you. That cortisone shot won't last forever.
dad911 01-04-2021 03:58 PM
How is that hitch for moving trailers around?
Rusty Heap 01-04-2021 04:01 PM
the QD seems like it'd add a lot more slop.
wdfifteen 01-04-2021 04:21 PM
Piece of cake. I don't have to get off the tractor.
