I do not care about the torque on my starter bolts. And I don't care if he uses power tools to save time. |
I was just kidding , but not really . Here , every critical fastener , gets torqued to factory spec, including wheels, every time without exception
I never finish tightening with cordless tools, always done by hand. There are however, lots of non critical fasteners , that just get blasted in the 3/8" impact, and final tightened with my calibrated arm. The alternator bracket , or transmission crossmember on your rusty pickup does not really care how tight they are . The spec for things like that is guten tite. I have a cordless screwdriver that I use to run belly pan screws in . They are a pain for all of us . |
I watched a factory gm mechanic, re assemble a warranty motor job, with no torque wrench, mains, rods, heads etc, air gun, blap, blap , blap . Guy was lighting fast, and made big money , but that is just wrong .
I use a cordless drill to run nuts on many times because you can adjust the torque.
And then while trying to remove a rusted on bolt after soaking it in penetrating oil, I still broke my extension with my impact driver. http://forums.pelicanparts.com/uploa...1610215361.jpg |
| All times are GMT -8. The time now is 02:51 PM. |
