Bambu labs if you want to make parts and don’t want to tinker.
However, as a tinkerer, I’ve been finding great printers used on Facebook for sub$100, from people “upgrading” to a bambu. |
I'd like to speed up my print speed but I wonder if print speed is more dependent on the printer or the print filament.
As far as print filament goes, I don't see much point to printing in PLA unless it's just for demonstration or toys since it doesn't stand up to heat. I print almost exclusively in ASA which is like a UV resistant ABS. I'd like to try poly carbonate but I've been too lazy to change to a high temp print head. Info on ASA: 3DXMAX® ASA (Acrylonitirle Styrene Acrylate) is a UV-resistant, famously weatherable polymer. Our ASA has a low-gloss matte finish which makes it the perfect filament for technical-looking prints, especially when you don’t want the high-gloss surface finish often associated with 3D printing materials like ABS, PETG, or PLA. |
A small 3D ditty
http://forums.pelicanparts.com/uploa...1702850937.jpg
Not too bad for a first try at a key chain. Nice and light, pretty close to Guards red.SmileWavy Charles |
That printer suckkkkks as you can see the layers...
Play with the temperature and speed. |
Printed a 1:1 scale A10 round.
http://forums.pelicanparts.com/uploa...1702925238.jpg You can also do lithophanes. Was a bad print, but you get the idea. http://forums.pelicanparts.com/uploa...1702925298.jpg http://forums.pelicanparts.com/uploa...1702925298.jpg |
Or RC rims (the Fuches could have come out better if I played with the settings a bit, they are 1:10 scale 17" rims:
The old Ford and off road racer are from the 80s. http://forums.pelicanparts.com/uploa...1702925557.jpg http://forums.pelicanparts.com/uploa...1702925557.jpg http://forums.pelicanparts.com/uploa...1702925557.jpg http://forums.pelicanparts.com/uploa...1702925557.jpg |
3D printing for idiots
Up n running, just learning some ropes
Test benchy https://uploads.tapatalk-cdn.com/202...6cc6e0ced7.jpg https://uploads.tapatalk-cdn.com/202...c36a82a384.jpg https://uploads.tapatalk-cdn.com/202...c8e4c63df8.jpg https://uploads.tapatalk-cdn.com/202...90cfe0db2c.jpg https://uploads.tapatalk-cdn.com/202...3ab821994b.jpg https://uploads.tapatalk-cdn.com/202...4108eb425e.jpg https://uploads.tapatalk-cdn.com/202...5fa6b6a45e.jpg https://uploads.tapatalk-cdn.com/202...e60ef94689.jpg https://uploads.tapatalk-cdn.com/202...8c57748e9c.jpg https://uploads.tapatalk-cdn.com/202...0aa8bf27f7.jpg |
| All times are GMT -8. The time now is 01:18 AM. |
